Guest neius Posted April 4, 2006 Share Posted April 4, 2006 My 94 pathfinder does not start. When I turn the key, my pathfinder only makes one click sound, (the sound is located near the driver's side fuse box), then nothing. Last week it did the same thing, but then I tried once more and presto, the truck started. I didnt think much about the problem until now. Also, on my last start of the truck, the starter sounded like my battery was low. Currently, I have tried to jump start the truck, change the batt, but with no avail. Can you help me? Link to comment Share on other sites More sharing options...
fordsho90 Posted April 4, 2006 Share Posted April 4, 2006 5 speed or auto?......kinda sounds like starter Link to comment Share on other sites More sharing options...
94extreme Posted April 4, 2006 Share Posted April 4, 2006 starter going, going, going.. use BFH on it. that may help for now but you'll need a new one. Link to comment Share on other sites More sharing options...
SC88Pathy Posted April 4, 2006 Share Posted April 4, 2006 Definatly the starter. Give it a good whack with a hammer and you'll get a couple more starts out of it, but it needs to be replaced pronto. Link to comment Share on other sites More sharing options...
Guest neius Posted April 4, 2006 Share Posted April 4, 2006 Thanks 4 all of your help. My truck is an auto. I'm thinking starter as well. Thanks! Link to comment Share on other sites More sharing options...
kruddy Posted April 20, 2006 Share Posted April 20, 2006 let us know whats up. Link to comment Share on other sites More sharing options...
ILoveMyPatty Posted April 22, 2006 Share Posted April 22, 2006 You can hit starters with a hammer and they'll work a little longer!? Whaaat, that's a nifty trick I tell ya. Link to comment Share on other sites More sharing options...
88pathoffroad Posted April 22, 2006 Share Posted April 22, 2006 If the brushes are shot, then a good knock will often free them up a little and make the starter work for a little longer. Like, maybe three or four more starts. Link to comment Share on other sites More sharing options...
Lucky92 Posted April 23, 2006 Share Posted April 23, 2006 And the old "whack it with a hammer" trick works wonders on any vehicle, from a Geo Metro to a Peterbuilt tractor. It's just that the solinoid (sp?) is shot. You NORMALLY have to have someone crank on the key while you bang away. At least that is what I remember from an old Impala I had. Link to comment Share on other sites More sharing options...
RedPath88 Posted April 23, 2006 Share Posted April 23, 2006 A bit late, but... does your power level also start to drop (or drop out completely) after the click or after a couple more tries? Check all battery connections, from the terminal to post to the connections at the starter and the grounds. Take the terminals off and clean the inside of them and the battery posts. If you have aftermarket terminals that clamo on to the cables then take the cable out, clean it and the terminal and reinstall them. Might even cut the end of the cable off. strip back the insulation a bit more and reinstall the terminals. That way you have some fresh metal to make the contacts with Starter and grounds, remove them and cleanup the contacts... scrap them if need be to expose shiny metal. I have had this happen on a number of vehicles in the past... sometimes its just a matter of cleaning electrical connections and not replacing major parts Link to comment Share on other sites More sharing options...
Precise1 Posted April 24, 2006 Share Posted April 24, 2006 Ditto to Red. I wouldn't consider touching the starter before checking all the connections... Have you tested the battery ? B Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted April 24, 2006 Share Posted April 24, 2006 As the last two posts suggested. Nine times out of ten it is the solinoid that sticks, not the starter. Give that a bash and you may get years more out of it. It happend to one of my other cars once. Link to comment Share on other sites More sharing options...
