crankshaft pulley bolt
nissandoms47
And they have a torque wrench and a manual? Good shop.
i doubt they have a manual but i am sure they have spec sheets or something.. yes, they use a torque wrench.. that's why i still go to them even though i live on the opposite side of town.. even my mudders are form there and have road hazard warranty on them.. see how many places will do that on a mudder sometime..
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
I was not having a go at you RP88.  :beer:
I know you were not :beer: Just expanding for any who might have thought that I just "good enough"'ed everything ;)
You'd freak to know how I loosen the bolt then.
Not likely, I have some rather "creative" way's of breaking things loose myself :D
As for doing everthing to spec, I would love to see the manuals you guys use.
When I say "everything to spec" I simply mean that if a manual has a spec on it, I do it... just like the auto makers, I do it to cover my arse.
The 33in BFG Muds on my yota have full on/offroad hazard on them... if they cannot fix it, they replace it :aok:
Two of the BFG AT's (the KO's) on my Path have the same, the other two (pre KO's) I bought used, with less than 100 miles on them.
I use a breaker bar and rest it against the chasis. I remove the EFI relay and then turn her over. One loud bang and she is loose. If there is another loud bang then something went horribly wrong. I have been working with cars longer than I care to remember and it has not happened yet. :hide::aok:
well i've been around plenty of shops that use the goodnuff policy ...i'll use it to a certain extent but not the extremes i saw...the valve covers being 1 cuze i dont see trying to put an adapter on a torque wrench to strip out a phillips head...but as far as engine internals yes i do those and on the driveline with a lil bit of threadlock
but one question for all...esp after the technical engineering aspect
The idea behind "torquing" is to tighten the bolt until the head is being pulled down hard enough to "stretch" the shank of the bolt an ideal amount.
You want to stretch it as that tension leads to a constant and considerable friction force in the threads and between the head and part to keep it from loosening. The more it is elastically deformed, the more it clamps. But only within the "elastic" range of the bolt.
If you stretch it beyond the elastic zone, then the clamping force no longer increases and instead the bolt just stretches in what we call plastic deformation - which means it is permanent deformation and does not reverse when the force is removed. And when that happens, two things happen: 1) It changes the granular stucture of the metal, and 2) it necks down and gets smaller in diameter.
after the bolts are torqued to yeild they shouldnt be reused...how many folks reuse these bolts...i know i have reused my head bolts which is a big no no in lots of peoples books and could cause me problems but i did that before i really knew about all that good stuff...
Ummm.... I have. sssh
Probably at least a few times before I knew better.
And a couple times after.... But I accept responsibility for doing so. I thought hard about what the risks were, and if there was any chance they had been reused more than once. I chose to reuse them once - but I would not do it twice. Each time they yield, they neck down a little more.
And so far, I've gotten away with it! But that doesn't make me any more confident I always will. Again, it is all about the risk. Some bolts from a particularly good batch of base steel could probably be reused 20 or 30 times before they failed. But one with an internal flaw? Nyet.
alright now that i know how to torque the bolt. why wont my engine start? when i cranked it over the first time i left the socket and ratchet on the bolt. would me not torqueing it good enough screw up the timing sprocket? so then the cams arnt doing anything.
thanks for you help
-Alex
I had a look at my wifes manual. Not one mention of not reusing head bolts. However, and I have not looked it up yet, it will say not to reuse the fly wheel or ring gear bolts again.
It is a good point you make.
i might would pop the top timing cover off...if the rachet got in a bind it could have snapped the timing belt or possibly made it jump a tooth?
thats prob not the case but if it was me that would be what happened cuze my luck stinks...hope ya get it figured out with minimal damage to the bank account
alright ill have a look at it. cause when i cranked it i only did it for about 1 second just to see if the starter was working correctly but i looked under and it was just caught on the sway bar but loosened the bolt. so i dont think it screwed up the timing cover or what ever. but should i look at the timing belt? ive never done anything with the timing before on a car so i dont have any experience. what is the timing belt made of?
thats what the timing belt looks like
well to check the belt u need to pull the belts and if u have a tensioner pulley the bracket for that and then theres like 6 or 7, 8mm bolts that hold the upper timing cover on...pop it off and if you dont see the belt or the belt has slack in it this is bad but if not it still could have skipped a tooth and i dont really know how to tell ya ot check that except to pull it all off and check the marks on the cams and crank...
if you have a FSM or haynes or chiltons read up on that about it a lil bit...but i'd also wait to see if some of the more knowledable guys on here have an opinion about it being a timing belt
well 1st off i just kinda thought i didnt really see where what year model and motor u have...i've got a vg30 motor which is an interference motor i belive the 4 bangers have a chain and arent interference but could be wrong
when i broke my belt i bent 3 valves which meant i had to rebuild the top half and it cost me about $300 to do it myself b/c if u dont tear up the heads or shatter a piston u have to buy a engine gasket set valves and the timing belt which is like $20 or so
as for the marks the cam gears will have a dimple in them and on the top right (driverside) and top left (pass side) there is a bump in the rear timing cover the crank should have 1 (my truck didnt have 1 so we made 1 after we set # 1 to TDC) but all 3 sets of dimples/bumps should line up at some pt it might take a couple revolutions with the crank to make it easy if u can figure out the position of the rotor in the dist cap the marks should line up when cylinder #1 is suppossed to fire
::edit:: saw its a 96...and i also saw on napa it was like $50 for a timing belt for ure truck...im guessing its still an interference motor but dont hold me to that...and i'd still wait around for some other folks inputs on the whole timing belt thought b/c i still donno how probable it is and im sure some1 knows more than i about this
Edited by unccpathfinder
Some designs require the fastener to be torqued to yield, some do not. If the manual doesn't say to replace, you can reuse.
Glad to see some folks make good use of manuals! They're not just for breakfast...
