vidro Posted November 1, 2005 Share Posted November 1, 2005 (edited) I maybe on drugs but I'm not crazy, someone try and explain something to me When I was doing the T-belt and Water pump I removed the "scuff plate" from front underneath the vehicle, I did this to get a better shot at the radiator drain plug. After putting everything back together I left the scuff plate off. I'm a real pessimist when it comes to my handy work, I figured I will need to get back under there for something else. Here's the part where either I didn't fix the exhaust leak and I'm being carbon monoxide poisoned or the scuff plate has something to do with stabilizing the front end. I have made reference in previous post of the front end "wobbling" on my Pathfinder but with the scuff plate off it seems to have settled down. Is this a coincidence or could there be something legitimate going on here? Edited November 1, 2005 by vidro Link to comment Share on other sites More sharing options...
Filthy Luker Posted November 1, 2005 Share Posted November 1, 2005 It's definitely the drugs. Link to comment Share on other sites More sharing options...
Precise1 Posted November 1, 2005 Share Posted November 1, 2005 I second that... No, it should make no difference what so ever to the front end stability, or lack of. Maybe things have settled now that you are driving it (sometimes) or it's just the drugs making you less observant... B Link to comment Share on other sites More sharing options...
madhatter_xe Posted November 1, 2005 Share Posted November 1, 2005 Your truck must have LSD.... wow....that was one weak joke. BUT, it's one more post on my tally. Link to comment Share on other sites More sharing options...
GrimGreg Posted November 2, 2005 Share Posted November 2, 2005 Yep, you need stronger drugs Link to comment Share on other sites More sharing options...
denisb Posted November 2, 2005 Share Posted November 2, 2005 Unless you can do a couple hundred Mph with a pathy, I would say the skid plate doesn't play a big role in aerodynamics.......at least not enough to make the truck have enough aerolift to make a difference I have to give another vote for .......um......drugs. Denis Link to comment Share on other sites More sharing options...
solid snake Posted November 2, 2005 Share Posted November 2, 2005 I took mine off recently because I was inspecting my tranny cooler, and I didn't see any difference in steering. I am thinking of fabbing one up when I lift the front with the trailmaster lift though. Link to comment Share on other sites More sharing options...
Slick Posted November 2, 2005 Share Posted November 2, 2005 add my vote to drugs Link to comment Share on other sites More sharing options...
Dowser Posted November 2, 2005 Share Posted November 2, 2005 It Absolutely has something to do with it. I'm Posative. Really.... Hold on a sec. *Passes Joint, Mushrooms, Acid, and some Pills with Scuff Plates drawn on them to a Friend* Your up man, and don't waste it like that time you poured that bag of dope down the toil... Oh ya, Forgot I was online.. Ahem... Now as I was saying... It's Totally Linked man. Totally. Dowser Link to comment Share on other sites More sharing options...
Revco Posted November 2, 2005 Share Posted November 2, 2005 ^^^^He has drugs with scuff plates drawn on them^^^^ I want what he's having. Where does Dowser come up with this stuff?? Link to comment Share on other sites More sharing options...
Casey.T Posted November 2, 2005 Share Posted November 2, 2005 I want what he's having. Where does Dowser come up with this stuff?? Its the Drugs Link to comment Share on other sites More sharing options...
vidro Posted November 2, 2005 Author Share Posted November 2, 2005 I guess I need to find a different dealer, I don't mind the BUZZ but I can't stand hallucinating. I agree, it's the drugs, and the road, the wind, and anything between 30ish and 50ish MPH. Sounds like tire balancing and rotation time. P.S. Anybody know of a Rabbi (not the plural for rabbit) that does exorcisms? Evidently what ever is possessing this thing has no comprehension of Latin. I am now hearing the exhaust pop coming from the drivers side exhaust manifold, I'm not brave enough to look, if I ignore it I know it will go away. Link to comment Share on other sites More sharing options...
Revco Posted November 2, 2005 Share Posted November 2, 2005 Maybe if you take more drugs, it won't matter anymore. Or wear BF earplugs. You might want to try a 50/50 holy-water to anti-freeze mix. Link to comment Share on other sites More sharing options...
Precise1 Posted November 3, 2005 Share Posted November 3, 2005 Try a quick check to see if the wheel bearings are tight (4x4s set to 0 play), tie rod ends, centerlink, and the arms. If that checks out ok, it may be bushings on the sway bar or in the CA's ? Just poke, pry and twist for a bit... Then get under and look... Anybody know of a Rabbi Have you tried slaughtering a chicken yet ? I find a granite 'altar' works well, followed by dancing around a bonfire naked wearing a goats head while chanting... These demons are far too ancient to respect any 'new' gods ! :o B Link to comment Share on other sites More sharing options...
Mr. Pickles Posted November 3, 2005 Share Posted November 3, 2005 It Absolutely has something to do with it. I'm Posative. Really.... Hold on a sec. *Passes Joint, Mushrooms, Acid, and some Pills with Scuff Plates drawn on them to a Friend* Your up man, and don't waste it like that time you poured that bag of dope down the toil... Oh ya, Forgot I was online.. Ahem... Now as I was saying... It's Totally Linked man. Totally. Dowser This guy is UW material. Link to comment Share on other sites More sharing options...
