Part Identification
I found this extra-clean Pathfinder on Ebay (listed under parts, for an odd reason). Here's a picture of the engine bay:
What is that plastic pipe running over the radiator fan shroud? I have one that is kind of cut off and doesn't run all the way across. I thought it was to quiet the engine down and it probably is, but why the difference?
Here's a link to the actual page, just for those of you who are curious:
Click Here
Hey wheelman, if it's what I think it is, it will be part# 16585 88g10. When I bought my pathy, if ound the tube in the back, never knew what it was for...now I know where it goes. By any chance, does any one know a site where we can search for oem part#'s?
quick question for you guys, can you point out to me where the PCV valve screw into the manifold? I know there is one rubber hose coming out of the intake pipe, but I can't follow it under the manifold. I hope it's not a p.i.t.a. to change them.
Yes. Changed mine in 0.3 seconds..... like Greg said.. DS.. just "behind" (firewall side)where the throttle cable sits in it's 'first" holder...
