wheelmanLS1 Posted July 19, 2005 Share Posted July 19, 2005 I found this extra-clean Pathfinder on Ebay (listed under parts, for an odd reason). Here's a picture of the engine bay: What is that plastic pipe running over the radiator fan shroud? I have one that is kind of cut off and doesn't run all the way across. I thought it was to quiet the engine down and it probably is, but why the difference? Here's a link to the actual page, just for those of you who are curious: Click Here Link to comment Share on other sites More sharing options...
solid snake Posted July 19, 2005 Share Posted July 19, 2005 Hey wheelman, if it's what I think it is, it will be part# 16585 88g10. When I bought my pathy, if ound the tube in the back, never knew what it was for...now I know where it goes. By any chance, does any one know a site where we can search for oem part#'s? Link to comment Share on other sites More sharing options...
GrimGreg Posted July 19, 2005 Share Posted July 19, 2005 Just a sound resonator for the intake, I got one laying around here in my shed if anyone wants one. Link to comment Share on other sites More sharing options...
solid snake Posted July 19, 2005 Share Posted July 19, 2005 Wheelman, does yours have a plastic cap inside it, where the tube ends? Mine does, I don't even know if it should go there though. The cap would be closer to the side of the the radiator cap. Link to comment Share on other sites More sharing options...
Slick Posted July 19, 2005 Share Posted July 19, 2005 well thank you GG... solves a 2 year mystery.... Link to comment Share on other sites More sharing options...
M in KC Posted July 19, 2005 Share Posted July 19, 2005 Solidsnake, the tube should have a cap in it closer to the radiator cap. Link to comment Share on other sites More sharing options...
statikuz Posted July 19, 2005 Share Posted July 19, 2005 yep, i trashed mine when i went to a cone intake, its not super necessary. Link to comment Share on other sites More sharing options...
nige Posted July 19, 2005 Share Posted July 19, 2005 quick question for you guys, can you point out to me where the PCV valve screw into the manifold? I know there is one rubber hose coming out of the intake pipe, but I can't follow it under the manifold. I hope it's not a p.i.t.a. to change them. Link to comment Share on other sites More sharing options...
GrimGreg Posted July 19, 2005 Share Posted July 19, 2005 Right behind where the throttle cables are attached on the TB on the drivers side of the manifold. The PCV valve just looks like a bolt fitting where the 1/2" hose connects. Link to comment Share on other sites More sharing options...
Slick Posted July 20, 2005 Share Posted July 20, 2005 Yes. Changed mine in 0.3 seconds..... like Greg said.. DS.. just "behind" (firewall side)where the throttle cable sits in it's 'first" holder... Link to comment Share on other sites More sharing options...
GrimGreg Posted July 20, 2005 Share Posted July 20, 2005 BTW, it's been a while, but I think it was a 17mm to remove it. Link to comment Share on other sites More sharing options...
