Recommended Battery cca and coolant low on radiator
so i replaced my hose that goes somewhere in the manifold to the a/c thingy and after replacing it now the coolant on cold temp is below the brim around the radiator plastic cover level, i used screw clamps because the stock didn't fit the new hose, about the battery mine is already leaking acid and i need a recommended cca for a battery on it
Metele una bateria AGM. No estoy seguro, pero creo que ocupa del grupo 24 o 34. Si tienes membresia, fijate si Sam's Club en tijuas las vende. Yo compre la mia en Sam's en San Diego.
Edited by R50JR
Posted (edited)
alr thanks for the help, i will search for one, about the coolant issue it was just because it was a fresh replacement it is not consuming it anymore
Edited by ThatOneNissanGuy
forgot to add info
