VG30i Throttle Body adjustments
Josh_Path2346
Ive recently rebuilt my throttle body and I need to know how to readjust it. I was also wondering where I might be able to find a new Idle Up solenoid. If anyone could help me out Id greatly appreciate it. My specs are below
1989 Pathfinder
3.0 V6 VG30i
4x4
Automatic
1989 Pathfinder
3.0 V6 VG30i
4x4
Automatic
Two screws on the throttle body. One is horizontal and controls the base idle, you can adjust it easily with the truck running.  There is also the fast idle screw, It points upwards at an angle and controls the idle speed before the truck is warmed up.  You have to push a screw driver into it hard enough that it opens the butterfly valve pretty wide to get it to turn, otherwise you can't get the screw driver on it without removing the air filter housing because the angle it points at with the throttle body valve closed. Adjust it with the truck cold and off, then start the truck and see if it's where you want it. Rinse and repeat till satisfied. I have mine set around 1100 cold and 800 warm.
  • 3 weeks later...
Ive gotten it to finally start up again but now its surging when in park. The RPMs will go up and down endlessly while its sitting there. Fresh gas and everything too. When I turn it off, thin white smoke comes from around the throttle body. I have no idea what to do
There's some good info here, though of course the pictures are screwed up because Photobucket (apparently there's a browser extension that'll get you past that). Can you see where the smoke is coming from? Could just be oil and crap burning off, doesn't seem like the TB should be getting that hot though unless the mixture heater's kicking on for some reason or the smoke is drifting up from somewhere else. Does it also surge in gear? Does it clear up off-idle (revving it or driving)?
I had a look at the '89 manual. For an unstable cold idle, it suggests checking the ignition timing, the fast idle cam, the fuel regulator, the idle speed control valve, the EGR valve, the EGR solenoid, and then run codes, in that order; if that doesn't do it, unplug the cylinder head temp sensor and see if that changes anything. For an unstable warm idle, it suggests checking for vacuum leaks in the PCV system, the intake, and the vac lines, checking spark quality/plug condition/plug wires (I assume more for a misfire condition than for surging), timing, compression, and EGR. I would also check the electrical connections on the throttle body to make sure they plug in securely and the pins are clean and not oxidized. If a plug seems suspect, wiggle it with the engine running and see if the idle responds.
If you want a PDF of the '89 service manual, let me know and I'll try and remember how I got it to the last guy.
Never mind, I got it to work finally. What would timing do to effect the idle surging up and down? I'm sure the EGR and its solenoid work because I cleaned them out by hand. I've checked all my vaccum lines and there's nothing to suspect of them. Its not a fuel problem either, as for the first 10 seconds it runs (rpm at or around 3000) and then it drops idle (1500 rpm) and starts surging. Should I mess with the timing? I know there's no ignition problem, as I just replaced the plus and they all seek to work. I've never let it warm all the way up either, as I'm too scared to let it blow up
Edited by Josh_Path2346
Needed more information
Might sound stupid, but have you reset your ECU? I cleaned off my MAF recently and had the same surging while at idle afterwards (this was NOT an issue before cleaning MAF) - checked all vacuum lines, checked EGR, AIV, etc. Turns out the problem righted itself when I unplugged the battery for a few minutes and let the ECU reset itself.
Idles perfectly now and I think the A/F ratio is way better as a result as it smells way less of gas. We'll see if mileage improves after I fill up.
Edited by Hanks88
