hawairish Posted August 29, 2015 Share Posted August 29, 2015 No sweat! Totally agree...if this deal is a good one, and that's the extent of the problems, I would have jumped on it already. Definitely a good project if there aren't any major gremlins. Link to comment Share on other sites More sharing options...
Beatup96 Posted August 29, 2015 Share Posted August 29, 2015 If it has rust you'll want to check the strut towers . Link to comment Share on other sites More sharing options...
thorrinn123 Posted August 29, 2015 Author Share Posted August 29, 2015 isn't there a recall on those? Link to comment Share on other sites More sharing options...
Beatup96 Posted August 29, 2015 Share Posted August 29, 2015 isn't there a recall on those? Yes . Search it here there is a lot of info . If it has issues there I'd pass , otherwise I'd probably jump on it . Link to comment Share on other sites More sharing options...
thorrinn123 Posted August 29, 2015 Author Share Posted August 29, 2015 i looked in the engine bay at the shock towers they looked ok to me...or do i check them from inside the wheel well? Link to comment Share on other sites More sharing options...
Beatup96 Posted August 29, 2015 Share Posted August 29, 2015 (edited) i looked in the engine bay at the shock towers they looked ok to me...or do i check them from inside the wheel well? From the outside , behind the coil/strut assembly , down low . No need to open the hood . Looks can be deceiving , if you brought it in for the recall check they'd be poking it with a screwdriver or the like . Drivers side is usually the bigger issue . Edited August 29, 2015 by Beatup96 Link to comment Share on other sites More sharing options...
thorrinn123 Posted August 29, 2015 Author Share Posted August 29, 2015 ok ill have a check Link to comment Share on other sites More sharing options...
hawairish Posted August 29, 2015 Share Posted August 29, 2015 Here's the NHTSA bulletin: It's a very specific area of coverage near the strut. Link to comment Share on other sites More sharing options...
thorrinn123 Posted August 29, 2015 Author Share Posted August 29, 2015 i guess bring a screw driver and poke it... Link to comment Share on other sites More sharing options...
thorrinn123 Posted August 29, 2015 Author Share Posted August 29, 2015 i see it is quite the process that bulletin is from the states canada must have a equivalent bulletin i imagine. Link to comment Share on other sites More sharing options...
hawairish Posted August 29, 2015 Share Posted August 29, 2015 Yeah, though a couple pics are just what you need to look for. I'd presume something similar for CAN, but not sure. Link to comment Share on other sites More sharing options...
Prattage Posted August 29, 2015 Share Posted August 29, 2015 Don't want to hijack this thread.. but that recall still aplies? Do they ever "run out" or have a time limit on those recalls? also nice looking buggy for cheap. Like hawairish said. I would have already bought that thing lol Link to comment Share on other sites More sharing options...
hawairish Posted August 29, 2015 Share Posted August 29, 2015 Nope, recalls don't expire to my knowledge. 1 Link to comment Share on other sites More sharing options...
jyeager Posted August 29, 2015 Share Posted August 29, 2015 por15 the best way to treat the rust? Yes, POR15 is incredible. Paint it on right over rust. Totally encapsulates it forever. If you carefully apply it and the rust is contained to behind the flares, then you can put the flares back on afterwards without the need for any other cosmetic cleanup. Link to comment Share on other sites More sharing options...
thorrinn123 Posted August 30, 2015 Author Share Posted August 30, 2015 well some of the rust bubbles are about where the flares are so it will need to have some cosmetic cleanup done to it for sure and where the flares screw into the wheel well there is rust there so some form of repair needed for that too..... Link to comment Share on other sites More sharing options...
hawairish Posted August 30, 2015 Share Posted August 30, 2015 BTW, if you can get the VIN, you can check for recall items: http://www.nissanusa.com/recalls-vin#/ Link to comment Share on other sites More sharing options...
thorrinn123 Posted August 30, 2015 Author Share Posted August 30, 2015 Is that just for the U.S.? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
thorrinn123 Posted August 30, 2015 Author Share Posted August 30, 2015 Well no open recalls and the shock towers are good. Just the rust in the rear wells goes into where the back doors are Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
thorrinn123 Posted August 30, 2015 Author Share Posted August 30, 2015 That going to be a hard area to deal with? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
thorrinn123 Posted August 31, 2015 Author Share Posted August 31, 2015 Well when I drove it the engine overheated so I stepped back didn't want to get involved with a u known if it has happened before I'll keep looking. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
patqx4 Posted August 31, 2015 Share Posted August 31, 2015 Good call, if it overheats and the owner didn't disclose that, who knows what else he isn't telling you. Link to comment Share on other sites More sharing options...
Prattage Posted September 2, 2015 Share Posted September 2, 2015 Good call man. I bought mine without really looking at it. Turns out it's alot more work needed than I thought. All rust repair. Runs mint. I'm a sucker for a good running truck lol Link to comment Share on other sites More sharing options...
thorrinn123 Posted September 2, 2015 Author Share Posted September 2, 2015 well I found a 2001 xe with 5sp in better condition going to have a look at it this weekend. not as loaded but maybe that's ok too, Link to comment Share on other sites More sharing options...
whatchugot Posted September 8, 2015 Share Posted September 8, 2015 Buy it and then youtube the fix (it's there if you look hard). Great deal!!! Sent from my SAMSUNG-SM-G750A using Tapatalk Link to comment Share on other sites More sharing options...
CDN_S4 Posted September 8, 2015 Share Posted September 8, 2015 Oh and BTW, reference one of your much earlier posts, don't put anything but regular 87 into a Pathy. It says it right in the manual. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
