Dma251 Posted March 19, 2015 Share Posted March 19, 2015 Anyone have any ideas or experience with fabricating a mount for a single adult mountainbike? I'm considering a 2" squaretube coming out from the center of the spare with a rubber-lined clamp at the end that will grip the centertube of the bike. I would like to make it narrow enough for the tire to slide off over it, need be. I think I'm gonna break out the welder tomorrow..... Link to comment Share on other sites More sharing options...
Precise1 Posted March 19, 2015 Share Posted March 19, 2015 No reason why it wouldn't work. Your own imagination and skills will get it done... B 1 Link to comment Share on other sites More sharing options...
Slartibartfast Posted March 19, 2015 Share Posted March 19, 2015 I imagine it would be hard to tie a bike down to a 2" surface tight enough to stop it from pitching forward and backward (relative to the bike). Making some kind of support beam/clamp parallel with the bike (removable to get the tire off) might make for a much more stable mount. Maybe have a T-shaped section that slides into the 2" tube like a trailer hitch, or a piece of pipe that slides through the sides of the 2" tube and locks down with a bolt or a cotter pin? Easy enough to remove the cross piece if you need to get at the tire. Of course, there's a very real chance that I'm overthinking this. The funny thing is that I keep looking at a hacked-up bike frame a friend gave me and thinking that if I put lug studs where the crank used to be, and welded mounting plates where the handlebars and front fork used to be, it would make a half-decent tire carrier for the Scout. Link to comment Share on other sites More sharing options...
xterra Posted March 19, 2015 Share Posted March 19, 2015 There are a few Heeps around here that have bike carriers mounted to their spares. The two styles I've seen either mount around the tire or have a hub connector and removable pipe (pics below for inspiration). Link to comment Share on other sites More sharing options...
SpecialWarr Posted March 29, 2015 Share Posted March 29, 2015 Just as a thought: if you wanted you could weld some short tube sections to stand the bike off of the carrier and buttress the bike frame off of the spare tire. Link to comment Share on other sites More sharing options...
adamzan Posted March 29, 2015 Share Posted March 29, 2015 I have that second one xterra posted. It's very strong and holds 3 mountain bikes just fine. The mount goes under the tire and you bolt the tire down on top of it. Link to comment Share on other sites More sharing options...
nunya Posted March 29, 2015 Share Posted March 29, 2015 If like to suggest a hitch mount basket (if you have a hitch that is). I can secure 2 bikes to mine, or use it for firewood, going to the pick a part... Etc etc Link to comment Share on other sites More sharing options...
