Gas Tank Size
Bubbley11
Yea, that's a 15 gallon for sure, even with the base timing off and missing a cylinder I was still getting an easy 300 miles out of mine when I bought it. Now that the timing, sensors and vacuum lines are all new and firing on all six I get 380 or so out of my 20gal.....
I've been looking around on the internet and, as adamzan pointed out, while there seem to be some things listed as 15 gal units they are all the same dimensions which fit the 3.0
Collapse Tank Assy-Fuel - Part Code: 17201
17202-41G02
Tank Assy-Fuel
Replaced by: 17202-61G00
VG30E, VG30I 01 $467.20 $352.64
17202-41G08
Tank Assy-Fuel
Manufacturer's Note: Limited Availability
Z24I 01 $405.43 $306.02
Specifications:15 gallons / 57 liters34.38 x 20.75 x 11.75 in.With pan
PART#: REPN670108
MFR#: REPN670108
SPECTRA FUEL TANK, STEEL, SILVER, 15 GALLONS/57 LITERS -- 34-3/8 x 20-3/4 x 11-3/4 in.; With lock ring and pan; Does not include seals and f.....
PART#: SPINS8B
DORMAN FUEL TANK, STEEL, BLACK, SOLD INDIVIDUALLY -- 15 gallons/57 liters; 34.38 in. L x 20.75 in. W x 11.75 in. H; Includes lock ring and s.....
PART#: RB576814 MFR#: 576-814
Edited by SpecialWarr
I never checked my stock tank, but judging by my gas mileage records and how much I put in to fill it, it was a 21 gallon tank. I checked the aftermarket tank with water, and it was 21 gallons more or less. Can't really recommend the brand though, it wasn't made that well.
