Idler arms the same 87-95?
Trogdor636
As the title states...are 87-95 idler arms all the same. I know the pitman changed. Want one to rebuild with the Bandit bushings, and all I have is a 88 (and I'll I have had for the last 6+months are 2 doors.....) to pick one from.
I thought the taper was different... could be wrong tho
I think your right and I want to say that it's 86-92 (Pathy / 4WD HB) and 93-95 (Pathy / 93-97 4WD HB)
But iirc there was no exact date on the taper change, I think it was in the 92 model year (late I think)
Nissan FAST shows them as the same part
Yep! Shows the same part number all they way though from start to finish on the WD21
PART NUMBER: 48530-31G25
DESCRIPTION: IDLER ASEMBLY, STEERING
I had check courtesy parts and it showed one, just being cautious. A 93 showed up in the yard today so I might go pick that one anyway. Thanks everyone!
