DsR50 Posted February 25, 2013 Share Posted February 25, 2013 lets see them, im in the process of making one and would like some ideas. im using 4 inch exhaust pipe cut in half for low profile. Link to comment Share on other sites More sharing options...
MY1PATH Posted February 25, 2013 Share Posted February 25, 2013 my pics are in here somewhere but I tore it out and am re-doing it to match my new air box. 2" or 4" cut in half is a tight fit towards the front but there is JUST enough room. (On a WD21 at least.)My new design will be a custom molded fiberglass duct 1.5x3" and mate up to a small scoop on top of the fender. The scoop will be removable so I can add a full snorkel if I need it. Link to comment Share on other sites More sharing options...
DsR50 Posted February 25, 2013 Author Share Posted February 25, 2013 yea im making a full snorkel ill post pics of my design when i can, i have to lift the rear tomorrow when i get my wj springs Link to comment Share on other sites More sharing options...
muddfildvaynes Posted February 25, 2013 Share Posted February 25, 2013 I built my own out of PVC and a couple Spectre Adapters I bought a a local autoparts store, I think I spent about $100 on the supplies.... Link to comment Share on other sites More sharing options...
muddfildvaynes Posted February 25, 2013 Share Posted February 25, 2013 Link to comment Share on other sites More sharing options...
new4x4r Posted February 26, 2013 Share Posted February 26, 2013 3" exhaust pipe, some bedliner and a Precleaner. Link to comment Share on other sites More sharing options...
theexbrit Posted February 26, 2013 Share Posted February 26, 2013 I was wondering if a square pipe might look better than a round pipe? I thought of using 3" gutter down pipe, anyone tried this? Link to comment Share on other sites More sharing options...
Slartibartfast Posted February 26, 2013 Share Posted February 26, 2013 I suspect it'd look like your truck got in a fight with a house. PVC can be heat-formed, right? Why not pack a 4" tube with sand, heat it where you want bends, and form it to the truck? I do like the look of new4x4r's exhaust tubing though. 1 Link to comment Share on other sites More sharing options...
98r50fan Posted February 26, 2013 Share Posted February 26, 2013 heres mine an my friends xj with a 3inch an 31s im looking to change my snorkle to pvc and find some sort of prefilter or cover Link to comment Share on other sites More sharing options...
theexbrit Posted February 26, 2013 Share Posted February 26, 2013 I suspect it'd look like your truck got in a fight with a house. :laugh: :laugh: I think the exhaust pipe one looks good because it exits the fender further back. Link to comment Share on other sites More sharing options...
headpeace Posted February 26, 2013 Share Posted February 26, 2013 3" exhaust pipe, some bedliner and a Precleaner. Did you have a muffler shop bend it for you? Link to comment Share on other sites More sharing options...
new4x4r Posted February 26, 2013 Share Posted February 26, 2013 You can probably get the pieces off eBay. I just went to a shop and bought a mandrel 90, a 3 foot straight and a 45. Welded them all together. Put some 1/16 tabs on it. The piping inside is justmarine exhaust tubing. Its very simple. Link to comment Share on other sites More sharing options...
DsR50 Posted February 26, 2013 Author Share Posted February 26, 2013 I suspect it'd look like your truck got in a fight with a house. PVC can be heat-formed, right? Why not pack a 4" tube with sand, heat it where you want bends, and form it to the truck? I do like the look of new4x4r's exhaust tubing though. i like that idea, any more info on this?? Link to comment Share on other sites More sharing options...
Blevinger Posted June 18, 2013 Share Posted June 18, 2013 Theexbrit, where is your version? Link to comment Share on other sites More sharing options...
WyKi Posted June 18, 2013 Share Posted June 18, 2013 I made mine on my white 91, didnt even spend 30bucks on supplies, bent it with heat (PVC). let me see if i could find my post. Link to comment Share on other sites More sharing options...
Bluewulf73 Posted June 19, 2013 Share Posted June 19, 2013 (edited) link to mine... some of the photos are not showing but if you click on one that does work, once you're on the page, you'll be able to see 'em all. Snorkel Edited June 19, 2013 by Bluewulf73 Link to comment Share on other sites More sharing options...
theexbrit Posted June 25, 2013 Share Posted June 25, 2013 (edited) Theexbrit, where is your version? Here's my finished product. Not exactly home made, more of a heavily modified Cherokee snork....... Cost me less than $150 total. Edited June 25, 2013 by theexbrit 1 Link to comment Share on other sites More sharing options...
Blevinger Posted July 1, 2013 Share Posted July 1, 2013 How does one decide weather or not to run a pre-cleaner like New4x4r? Any of you with the "typical" snorkle top worry about water getting in there and soaking the stock filter when it's raining? Very curious. Link to comment Share on other sites More sharing options...
theexbrit Posted July 1, 2013 Share Posted July 1, 2013 How does one decide weather or not to run a pre-cleaner like New4x4r? Any of you with the "typical" snorkle top worry about water getting in there and soaking the stock filter when it's raining? Very curious. In So Cal I don't have to worry too much about rain Also, it's not my daily ride so I don't really drive it much when we do get some wet stuff. I made a pre-filter from a pond filter that I cut up, it keeps all the larger particles out & would probably stop a lot of rain from getting into the snork. You can angle the head of the snork down at an angle which will also help stop rain getting in, plus the Safari "scoop" such as mine has outlets at the bottom of the head unit to allow water to drain. That's about all I can think of to stop rain getting in aside from the pre-cleaner that new4x4r has, that's the best way to keep rain out. 1 Link to comment Share on other sites More sharing options...
Rebelord Posted July 1, 2013 Share Posted July 1, 2013 I run a 200 micron teflon coated SS screen mesh. 99.99% Water proof. 1 Link to comment Share on other sites More sharing options...
theexbrit Posted July 1, 2013 Share Posted July 1, 2013 Damn, I forgot to mention that rebelord has the best water proof solution. That screen is a great idea! Link to comment Share on other sites More sharing options...
Blevinger Posted July 2, 2013 Share Posted July 2, 2013 Good info! 1 Link to comment Share on other sites More sharing options...
CDN_S4 Posted July 19, 2014 Share Posted July 19, 2014 Is there a noticeable negative difference in performance? Many of these snorkels point away from the wind (minus Xbrit) so no air is being pushed into the intake. Plus the longer path it has to travel and the fact that it will be warmer by the time it reaches the intake manifold. Seems to me like it would be a performance robber. No? Sent from Tapatalk Link to comment Share on other sites More sharing options...
