jdubs12 Posted February 5, 2013 Share Posted February 5, 2013 Hi everyone, so recently (after some significant driving in 4x4) i noticed my front left has a terrible squeel/metal on metal rubbing noise. It has gotten worse over the last two weeks.Some recent changes are I had an alignment, swapped to winter tires (smaller then my reg. tires), and I put in new ball joints.... I am thinking (actually my friend who knows more about this @!*% is thinking) that its the bearing.... how do i tell if its garbage? That being said, anyone have any other suggestions as to what it might be? Another friend mentioned something about my axle and in which case he said i'll have a hell of a time replacing it. I will take the wheel off and have a look this weekend when I have the time.Cheers Link to comment Share on other sites More sharing options...
Slartibartfast Posted February 5, 2013 Share Posted February 5, 2013 Jack it up, grab the wheel, check it for excessive play (up/down, side to side). I doubt it's an axle (CV) unless it only does this in 4x. Link to comment Share on other sites More sharing options...
jdubs12 Posted February 5, 2013 Author Share Posted February 5, 2013 kk will do - i feel like i should add its only when I make left hand turns, sometimes gets louder if i brake while turning Link to comment Share on other sites More sharing options...
k9sar Posted February 5, 2013 Share Posted February 5, 2013 ummm... you checked your brake pads, right? Link to comment Share on other sites More sharing options...
Leo94 Posted February 5, 2013 Share Posted February 5, 2013 Is this all the time or when slowing down or when turning or when going over a bump or when accelerating or a combination of the listed? Link to comment Share on other sites More sharing options...
Precise1 Posted February 5, 2013 Share Posted February 5, 2013 i feel like i should add its only when I make left hand turns Absolutely! This makes me think bearings also, perhaps with a side of brakes. Do what Slarti said... B Link to comment Share on other sites More sharing options...
jdubs12 Posted February 5, 2013 Author Share Posted February 5, 2013 I checked the brakes and I can't see what it would be rubbing...it's only turning left, Id say it varies depending on speed, braking used to make it happen (going left only) but now regular left hand turns do it regardless of braking. Link to comment Share on other sites More sharing options...
jdubs12 Posted February 5, 2013 Author Share Posted February 5, 2013 K sweet... Midterms are almost over for me so I will def have time to fix it this weekend Link to comment Share on other sites More sharing options...
jdubs12 Posted February 5, 2013 Author Share Posted February 5, 2013 so if it was the bearings would i replace the inner and outer or just the outer or whaaat? Link to comment Share on other sites More sharing options...
Remus92 Posted February 5, 2013 Share Posted February 5, 2013 Both? Tear into it and see which one if not both. Link to comment Share on other sites More sharing options...
jdubs12 Posted February 6, 2013 Author Share Posted February 6, 2013 ive never gone in deep enough to find the inner lol is swapping it out as easy as the outer? Link to comment Share on other sites More sharing options...
Precise1 Posted February 6, 2013 Share Posted February 6, 2013 Yes and no. The rotor has to be removed for both, the old races pressed out and the new ones pressed in. The outer will usually fail first, but many people just replace them as a set. Just jack it up and wiggle the tire first to see if that is the issue. It takes 15 minutes... B Link to comment Share on other sites More sharing options...
