pathy97 Posted January 27, 2013 Share Posted January 27, 2013 I replaced the right side upstream o2 sensor and it was black/foulded what could cause this? A vacuum leak? It doesnt burn oil. Link to comment Share on other sites More sharing options...
adamzan Posted January 27, 2013 Share Posted January 27, 2013 Well if the sensor was bad and the truck was running rich, I think that would be your cause. 1 Link to comment Share on other sites More sharing options...
fixinto Posted January 29, 2013 Share Posted January 29, 2013 which one is upstream sensor 1 or 2 or pre or post cat? Link to comment Share on other sites More sharing options...
Towncivilian Posted January 29, 2013 Share Posted January 29, 2013 Sensor 1 is always upstream. Link to comment Share on other sites More sharing options...
pathy97 Posted January 29, 2013 Author Share Posted January 29, 2013 correct Link to comment Share on other sites More sharing options...
fixinto Posted January 30, 2013 Share Posted January 30, 2013 gotcha thought so but didnt want to assume. =) Link to comment Share on other sites More sharing options...
nik905 Posted January 30, 2013 Share Posted January 30, 2013 You could have a fouled spark plug or have a bad catalytic system Link to comment Share on other sites More sharing options...
dynomax Posted February 28, 2013 Share Posted February 28, 2013 I replaced the right side upstream o2 sensor and it was black/foulded what could cause this? A vacuum leak? It doesnt burn oil. I am still debating on doing mine just to get some MPG. 10MPG is not very good. I have tried E10 87 octane, but generally run 91 premium E0, I really find no difference with either. two questions, how the heck do I get at these upstream sensors, and what sensors did you replace with??? part numbers would be cool too! Link to comment Share on other sites More sharing options...
dynomax Posted February 28, 2013 Share Posted February 28, 2013 I replaced the right side upstream o2 sensor and it was black/foulded what could cause this? A vacuum leak? It doesnt burn oil. did you replace both sensors, or just the one? I'm not getting any codes... Link to comment Share on other sites More sharing options...
sroeser01 Posted February 28, 2013 Share Posted February 28, 2013 Running premium fuel in your truck is pointless and your wasting money. Just fix the truck and it will run properly Link to comment Share on other sites More sharing options...
fastpakr Posted February 28, 2013 Share Posted February 28, 2013 Running premium fuel in your truck is pointless and your wasting money. Just fix the truck and it will run properly The QX4 specifies premium fuel, is this not the case on the VQ in the '04 Pathfinder? I realize the VG in your 97 doesn't require it. Link to comment Share on other sites More sharing options...
Towncivilian Posted February 28, 2013 Share Posted February 28, 2013 All Nissan / Infiniti models with the VQ35DE recommend premium fuel. There is certainly a benefit to doing so, I notice better engine performance over 87. VG engines will not benefit from premium. Link to comment Share on other sites More sharing options...
