AzZo Posted December 31, 2012 Share Posted December 31, 2012 Best way to explain is this noise is new.It sounds like a knocking or clunking only when i go over bumps not on smooth pavement or road.I crawled underneath and everything is tight nothing is loose.It has new shocks the coilsprings look fine. The frames rusty could it be separating from body?I had plans to weld metal plates to rusted frame in spring did I wait to long? Any suggestions would be helpful.It runs fine doesnt act any differently just noisey. Link to comment Share on other sites More sharing options...
Precise1 Posted December 31, 2012 Share Posted December 31, 2012 Let the person out of the trunk? Oh, wait, it's a Pathy... How do the bushings look on the pan hard rod and the rear links? Hopefully its not the frame, that would be pretty bad... B Link to comment Share on other sites More sharing options...
silverton Posted December 31, 2012 Share Posted December 31, 2012 It's probably either the upper or lower link, looks fine on a visual inspection, but your eyes don't have the ability to make a 4000 pound weight flex the bushings over a bump. Link to comment Share on other sites More sharing options...
Slartibartfast Posted December 31, 2012 Share Posted December 31, 2012 Do you have a camcorder? Try mounting it under the truck somewhere, then drive over a bump and see if you can tell what's moving around. I'd bet on a bushing rather than the frame. That said mine makes a crazy knocking/rattling noise when I go over bumps, and it's because my tire carrier bushings are shot. Slam your tire carrier shut (or have someone else do it while you're inside the truck) and see if it makes the same noise. Link to comment Share on other sites More sharing options...
adamzan Posted January 1, 2013 Share Posted January 1, 2013 Check your sway bar links Link to comment Share on other sites More sharing options...
AzZo Posted January 2, 2013 Author Share Posted January 2, 2013 Let the person out of the trunk? Oh, wait, it's a Pathy... How do the bushings look on the pan hard rod and the rear links? Hopefully its not the frame, that would be pretty bad... B Thanks but no body in the back I will leave that to the amish mafia,HA,HA, Good advice B will check bushings they most likely need replacing. Link to comment Share on other sites More sharing options...
gv280z Posted January 5, 2013 Share Posted January 5, 2013 I get something like that every now and then but only on more severe jolts, I have begun to assume its the torsion bar "slapping" against the under-carriage. Link to comment Share on other sites More sharing options...
Inyourface1650 Posted January 5, 2013 Share Posted January 5, 2013 Check your rear link bushings, just fixed the problem for me! Link to comment Share on other sites More sharing options...
AzZo Posted January 6, 2013 Author Share Posted January 6, 2013 TO all I crawled underneath and took a serious look.And it's not the frame most likely culprit is bushings. Are they really hard to replace? Do they need to be pressed in.Note there is a foot of snow on ground out here so I will probly wait till spring and warmer weather.Thank you for the support. Link to comment Share on other sites More sharing options...
Slartibartfast Posted January 6, 2013 Share Posted January 6, 2013 My understanding is that you drill out the stock bushings, then get two-piece poly bushings and press those in by hand. Link to comment Share on other sites More sharing options...
Inyourface1650 Posted January 6, 2013 Share Posted January 6, 2013 (edited) I've got a set of the poly I can sell you if you'd like . I just pulled complete links from the junk yard. They don't take long, but the bolts are tight... You'll need a 1/2 ratchet and a 2 or 3 foot breaker bar. You can get them all Off which the truck sitting on its tires... Just work from underneath Edited January 6, 2013 by Inyourface1650 Link to comment Share on other sites More sharing options...
AzZo Posted January 7, 2013 Author Share Posted January 7, 2013 I get something like that every now and then but only on more severe jolts, I have begun to assume its the torsion bar "slapping" against the under-carriage. And what can be done to remedy this situation?What would cause the torsion bar to flex so much that it slaps the under body? Does it mean it's word out? Link to comment Share on other sites More sharing options...
Slartibartfast Posted January 8, 2013 Share Posted January 8, 2013 I can't imagine how the torsion bar would slap anything short of it being well and truly buggered (like snapped in half or bent to hell). Link to comment Share on other sites More sharing options...
Inyourface1650 Posted January 20, 2013 Share Posted January 20, 2013 Torsion bars are in the front...you have suspension links (trailing arms?) in the back. BTW I just got yet another one from the jy for $12.99. Link to comment Share on other sites More sharing options...
