stalker Posted January 10, 2012 Share Posted January 10, 2012 what are things in need to look for that will not work with this for SAS my 94 pathy. i found the entire truck for $250 should i jump on this deal.? Link to comment Share on other sites More sharing options...
itsme1738 Posted January 11, 2012 Share Posted January 11, 2012 probably not....there no parts from a stock pathy that will help you with your sas Link to comment Share on other sites More sharing options...
kodi3482 Posted January 11, 2012 Share Posted January 11, 2012 (edited) ? so if you found an 87 pathy for $250 i'll go in halves with you on it since we're both local lol or if you pass on it let me know.. i might want it Edited January 11, 2012 by kodi3482 Link to comment Share on other sites More sharing options...
Heloflyboy Posted January 11, 2012 Share Posted January 11, 2012 Front axle and leaf springs , as long as it does not have vac. disconnect. Also keep front driveline you might be able to use it also . Link to comment Share on other sites More sharing options...
tmoore4512 Posted January 11, 2012 Share Posted January 11, 2012 Stock wagoneer, or a stock pathy? The initial post is a bit confusing...or I am just tired one... If its a wagoneer, jump on it. You can scrap what you dont use for MORE than you paid... If its a stock pathy, still a good deal if your wife/significant other wont mind it sitting somewhere so you can rob parts off of it... Link to comment Share on other sites More sharing options...
AK9849cy Posted January 11, 2012 Share Posted January 11, 2012 Vacuum disco? Link to comment Share on other sites More sharing options...
tmoore4512 Posted January 11, 2012 Share Posted January 11, 2012 Ryan has a good point....if it is vacuum, I would stay away from it... hard as crap to find workable parts for one... Link to comment Share on other sites More sharing options...
stalker Posted January 11, 2012 Author Share Posted January 11, 2012 Its a Wagoneer for 250 bucks...great...i am snaging it... Link to comment Share on other sites More sharing options...
stalker Posted January 11, 2012 Author Share Posted January 11, 2012 ? so if you found an 87 pathy for $250 i'll go in halves with you on it since we're both local lol or if you pass on it let me know.. i might want it i guess it was a crappy post...it is a wagoneer for 250. Link to comment Share on other sites More sharing options...
AK9849cy Posted January 11, 2012 Share Posted January 11, 2012 If the front diff looks like this.... don't do it. Link to comment Share on other sites More sharing options...
kodi3482 Posted January 11, 2012 Share Posted January 11, 2012 lol, its ok.. last time i took a car to the crusher i got $360 for it.. so you can't really go wrong i guess.. Link to comment Share on other sites More sharing options...
stalker Posted January 11, 2012 Author Share Posted January 11, 2012 If the front diff looks like this.... don't do it. thanks for the pic Link to comment Share on other sites More sharing options...
AK9849cy Posted January 11, 2012 Share Posted January 11, 2012 250 plus the gas to tow it there... So maybe make $50 bucks to tow it to the crusher. After the title is changed over to your name.. so a little more gas money... Link to comment Share on other sites More sharing options...
stalker Posted January 11, 2012 Author Share Posted January 11, 2012 (edited) 250 plus the gas to tow it there... So maybe make $50 bucks to tow it to the crusher. After the title is changed over to your name.. so a little more gas money... so if everything works out right ill get the Dana44 for frrreeeee...nice Edited January 11, 2012 by stalker Link to comment Share on other sites More sharing options...
AK9849cy Posted January 11, 2012 Share Posted January 11, 2012 so if everything works out right ill get the Dana44 for frrreeeee...nice Hopefully it works out that way. Link to comment Share on other sites More sharing options...
Tad Posted January 15, 2012 Share Posted January 15, 2012 If the front diff looks like this.... don't do it. That's '83-'84 FSJ only. Not a total deal breaker either. You can pull the diff cover, remove the vacuum stuff, slide the engaging collar over and secure it with a hose clamp or a few tack welds. Plug hole in diff cover from vacuum with a large bolt and a oil drain plug washer (it's up top so it will not leak). After that it's like a regular FSJ front D44, we've been doing it for years on full size jeeps. Only issue you get into is that if you break an inner shaft or the collar those parts are '83-'84 specific and getting a bit hard to find, but they are pretty beefy. You can also run the '80-'82 and '85-'91 inner shafts from an FSJ (needs to be same length NT or WT) but the inner oil seal will not make contact on the smaller axle shaft. That gets remedied with this so the gear oil will not leak out on an angle or when making right turns: Not a perfect solution, that would involve pulling the carrier and sourcing the correct size inner oil seal for that side. Link to comment Share on other sites More sharing options...
Mauitrailguy Posted April 22, 2012 Share Posted April 22, 2012 Either way its an awesome deal. Im picking up a set of D44's from a waggy for 400$ on tuesday. Link to comment Share on other sites More sharing options...
daver123 Posted June 1, 2012 Share Posted June 1, 2012 I frankensteined a dana 44 together. I got a bare housing and a bunch of spare pathy parts from my dentist, who by chance has the exact same truck and SASed, for free cuz the mrs' wanted them out from under the deck. I then picked up one of these internal disco's d44 for cheep and gutted it for parts. In the end the housing is a mystery where it came from, but the carrier, hubs, outter stubs and rotors are from the waggy, the flat top knuckles and spindles are a ford f250, inner shafts are chromoly, aftermarket 5.13 gears and HD diff cover, warn hubs, custom brake brackets to hook up the gm calipers, and of course all new bearings, seals, ball joints and u joints. Link to comment Share on other sites More sharing options...
