Everything posted by itsme1738
88 3.0 v6 30 degrees or lower it will not idle.....when its 30 or above,all is well
anyone know anything about the reed valve and the A I V AIR SYSTEM?
itsme1738 replied to itsme1738's topic in The Garage
thanks coung......found the air filter.....connot find the reed valve anywhere in the US stealership laughed at me! -
i have been really busy coung -
i love my 88....sas soa,513s with 35s....its my dd every day now for 4 years
87 twin turbo sas 1 inch lift...
itsme1738 replied to AK9849cy's topic in Solid Axle Swaps, Hardcore Custom Fab
nice -
i agree ryan,never cut corners......brakes and steering......took a little longer to save the cash but,it was well worth it.......flat top knuckles,high steer arms,1/4 wall dom,good tres,ect
i did alot of research before i sased,this was 4 to 5 years ago.....i saw that the largest problem with a 3 in sl lift was steering.....there was fixes but,they were indeed tempoary.speending another grand,i could skip the sl and,go sas,sooooo around 2-2500 bux i skipped the sl and,with the help of ryan and,bill..got it done in a little over a weekend,its my dd for over 4 years now and,i never looked back....im no crawler for sure but its suits my purpose! 88 pathy,sas,soa,513s----DD hope this helps your cause ryan!
ha! i was there when that happened.....i heleped him put in the spares in the rain, good times!!! and i seperated my front ds 4 trucks behind him i believe it was called the squeeze
anyone running 5.13 gears.?
itsme1738 replied to stalker's topic in Solid Axle Swaps, Hardcore Custom Fab
i have 513s/514s......its my dd 44 front 233a/b rear....a housing/b third....no real complants,speedo is 2 mph high -
Kinda makes me wonder...
i have the same hoop/shock setup on my rig....works great -
happened to me last year....when it snowed or rained(even parked overnight) it would run like crap...i tried everything...spent weeks....finally i grabbed the dist cap by accident and,it grabbed me right back,wow....turns out i had hair line cracks in the cap.....pull it off and use a bright light on the other side
hey ryan i weighed mine 2 days ago....3800 even -
4.33 is manual....4.6 is automatic
sooo ryan.....we can do the twin turbos on my rig then... -
i will be watching.....tap tap tap
87 waggy front axle (help)
probably not....there no parts from a stock pathy that will help you with your sas -
i cut my panhard bar then jacked the truck up to what i (thought) was right then,welded a sleeve around the ph bar....i still lean to the right and my bar is at a near 45 degree angle its ugly!!!!
listen to the dowser
and watch the video!
http://www.nissanpathfinders.net/forum/index.php?showtopic=31401 read this thread
i was gona comment on the wire nuts but i thought i would give ryan a break -
i should be getting 1 of these soon....i will let you know what happens
my 88 just rolled over 120.000 i guess im just getting started
ok ryan ...what i have done is lengthen my pan hard bar (to raise the rear of the truck)if i go with th 3 in drop do i have to shorten the bar(go back to stock)....i have not noticed any mis-aligement of the rear axle(just eye balling it) but i do have bad tire wear issues (the outsides wear first but i think i warped my axle while welding it)i have a new housing in the garage ready to be welded by a professional welder ok my question was would i need to go back to a stock bar? if i install one of your units
