nismothunder Posted December 6, 2011 Share Posted December 6, 2011 Would they fit? Will the wiring to the new ECU be a nightmare? William If you get the complete ecu from a yard with the engine then yeah, the engine/tranny will run perfect. Now the factory BS wont with out putting time into it. Link to comment Share on other sites More sharing options...
silverton Posted December 6, 2011 Share Posted December 6, 2011 will a VQ or VH even fit between the frame rails of a WD21? I know a VG30DET needs a whole bunch of massaging. With the 4.625 gear ratio, putting 33's on it (with a stock tire size of 31's) you've essentially changed your final ratio to 4.3. replacing your 4.6's with 4.9's from an Xterra will put you back at stock gearing. The bigger tires are of course making your truck feel sluggish. Personally, I would do a VG33 swap and put headers and exhaust on it. It's going to keep your truck down and out for the count for the fewest hours. HTH! Link to comment Share on other sites More sharing options...
ahardb0dy Posted December 6, 2011 Share Posted December 6, 2011 Years ago I inquired about a new gear ratio for my hardbody, can't recall if I spoke to Jim Connor or someone at Nismo but I was told with 33's switching to a 5.14 ratio would bring the RPM's back to what they would be with the stock 31's, I told the guy I was running 35's and he didn't have an answer for that. Link to comment Share on other sites More sharing options...
Tungsten Posted December 6, 2011 Share Posted December 6, 2011 Could always drop in a VG33E (96-00 pathfinder or 00-04 xterra) which makes 180hp and more if you do I/H/E. Or build a VG34. These would be more bolt on than a gm or jeep swap. The VG33 should be pretty easy to find what with nissan scrapping so many r50s due to strut tower rot. i think this is the best idea possible too Link to comment Share on other sites More sharing options...
sewebster Posted December 6, 2011 Share Posted December 6, 2011 (edited) Years ago I inquired about a new gear ratio for my hardbody, can't recall if I spoke to Jim Connor or someone at Nismo but I was told with 33's switching to a 5.14 ratio would bring the RPM's back to what they would be with the stock 31's, I told the guy I was running 35's and he didn't have an answer for that. I don't think that makes sense... it should be easy to calculate. The torque arm of the tire is just the radius of it, so it is proportional to the tire diameter. So you can just take your gear ratio, say 4.625 and multiply it by the ratio of tire sizes. 4.625 * 33 / 31 = 4.92. If you wanted it to drive the same with 33s as it would be 29s then you'd get 4.625 * 33 / 29 = 5.26, so you'd need 5.3ish gears. Of course if you had a 4.3 gear ratio to start with it changes everything too. edit I think I fixed the typo Edited December 6, 2011 by sewebster Link to comment Share on other sites More sharing options...
Precise1 Posted December 6, 2011 Share Posted December 6, 2011 (edited) But you might want to edit the number... B Edited December 6, 2011 by Precise1 Yep, that was it... Link to comment Share on other sites More sharing options...
Heloflyboy Posted December 6, 2011 Share Posted December 6, 2011 WOW! I think everyone that suggests the 3.3 swap have the right idea,add 4.90 gears you are done.How driveable do you want your P.F.? My experience is the more you change the more tinkering you end up doing to get everything working right.Is cost a factor? If it is think of what it will cost and double it. Trust me look at my truck.If you want V8 power buy a new pathfinder.If you want reliability keep your 100km 3.0 and change gears.Of course that's just my opinion.I am sure some will agree some will disagree. Link to comment Share on other sites More sharing options...
silverton Posted December 6, 2011 Share Posted December 6, 2011 He has an XE, so I reckon his truck came with the 235/75's which make it a 29" tire. But I think a 4.9 ratio would make your truck feel much more drivable. Link to comment Share on other sites More sharing options...
sewebster Posted December 6, 2011 Share Posted December 6, 2011 I have 4.3 gears and my engine is running at like 3000 rpm to go 60 mph. Seems like going higher would be not necessarily a good idea. I think I'm going to put together my gears spreadsheet I've been meaning to make for a while. I guess I can post it up and people can play around with this stuff. Link to comment Share on other sites More sharing options...
JamesRich Posted December 6, 2011 Share Posted December 6, 2011 I have 4.3 gears and my engine is running at like 3000 rpm to go 60 mph. Seems like going higher would be not necessarily a good idea. I think I'm going to put together my gears spreadsheet I've been meaning to make for a while. I guess I can post it up and people can play around with this stuff. My truck has 4.3 gears too. According to your spread sheet If I put 4.9 gears and 35" tires It will only be 20 RPMs different at 60 mph. Won't even have to change the speedometer gear. James Link to comment Share on other sites More sharing options...
94 Pathy Posted July 28, 2014 Share Posted July 28, 2014 My honest opinion of doing a 350 or 302 v8 swap.....cut all the crap out & run the vehicle like an old school muscle car. No power windows, locks, A/C, etc. Remember, it's a wheeling rig. All you need is the engine, tranny, steering, suspension, tires, and a seat for your ass. That's what I'm planning on doing when the time comes. Doors off & possibly even the tailgate. Install roll cage & drive it like you built it to be driven/off-roaded. 1 Link to comment Share on other sites More sharing options...
Goosevf_1 Posted August 6, 2014 Share Posted August 6, 2014 Would the vg33 bolt up to the stock tranny? basically just unplug, pull, drop in, hook it up and off the trails? Just the engine is about $600 from a jdm shop. Youre looking at an engine w/ 80 000kms. cant go wrong with that at all....dont have to deal with all the road grim, oil and rust as you would with a north american engine either. Link to comment Share on other sites More sharing options...
Leemarkus2 Posted July 22, 2022 Share Posted July 22, 2022 I got that engine from a junkyard, there i have seen many junk cars and from one of them i got the engine for my car. Link to comment Share on other sites More sharing options...
