blackspawn Posted September 18, 2011 Share Posted September 18, 2011 I'm about to change all my bushings(tension rod,upper/lower control arms,sway bar) in the frontend and was wondering which should I use. Winter is coming and my rig is starting to shimmy and shake. Which ones are you guys using? Link to comment Share on other sites More sharing options...
nunya Posted September 18, 2011 Share Posted September 18, 2011 I personally use poly replacements when I need to change something out. Personal preference plus Energy Suspension brand stuff is decent priced and you can get em off Steeevo @ Rugged Rocks Link to comment Share on other sites More sharing options...
blackspawn Posted September 18, 2011 Author Share Posted September 18, 2011 Poly is what I was thinking, its just going take me longer to get them shipped in and installed. I think it will be worth it. Link to comment Share on other sites More sharing options...
Simon Posted September 18, 2011 Share Posted September 18, 2011 I'm not sold on Poly stuff. Anything poly on my truck seems to wear out FAR faster than it's OEM, rubber counterparts. Yes, poly is stiffer, yes it's more readily available (aftermarket), but I don't think it's as durable as rubber. Link to comment Share on other sites More sharing options...
ditchdiggerjcf Posted September 18, 2011 Share Posted September 18, 2011 I'm not sold on Poly stuff. Anything poly on my truck seems to wear out FAR faster than it's OEM, rubber counterparts. Yes, poly is stiffer, yes it's more readily available (aftermarket), but I don't think it's as durable as rubber. I searched high and low recently for poly bushings, and had no luck at all. Where are you guys finding this stuff. Energy suspension doesn't show it anywhere I could find. Link to comment Share on other sites More sharing options...
wd21overland Posted September 18, 2011 Share Posted September 18, 2011 I searched high and low recently for poly bushings, and had no luck at all. Where are you guys finding this stuff. Energy suspension doesn't show it anywhere I could find. Poly bushings are the easiest to find. I would start at energy suspension website. http://www.energysuspensionparts.com/categories.asp?cat=Nissan+Pathfinder+4WD Or http://ruggedrocksoffroad.com or http://www.4x4parts.com/nissan or even my local parts store like autozone, napa and all them sell all the energy suspension lines of products. Link to comment Share on other sites More sharing options...
wd21overland Posted September 18, 2011 Share Posted September 18, 2011 Also on a side note Ruggedrocksoffroad.com seems to be the fastest place to order them from for me at least might depend on where you live though. Link to comment Share on other sites More sharing options...
ditchdiggerjcf Posted September 18, 2011 Share Posted September 18, 2011 Also on a side note Ruggedrocksoffroad.com seems to be the fastest place to order them from for me at least might depend on where you live though. I never found any of that when I looked. All the parts stores I checked(NAPA, O'reilly, bumper to bumper) offered no poly for my year model. My local off road shop told me that they were no longer available from ES. Link to comment Share on other sites More sharing options...
silverton Posted September 18, 2011 Share Posted September 18, 2011 I have picked up two used pairs of Rancho 9000s. They came with poly bushings of course. Unknown mileage on them but the shocks still worked great, and the bushings were cracked and crumbling. Whereas the rubber bushings on my stock shocks, even with 180,000 miles, still looked and felt new. Link to comment Share on other sites More sharing options...
blackspawn Posted September 18, 2011 Author Share Posted September 18, 2011 The only reason I was thinking (poly) is the longevity of the bushings. But if you hardcore wheelers are having better wear with the rubber ones then I'll get those. Link to comment Share on other sites More sharing options...
blackspawn Posted September 18, 2011 Author Share Posted September 18, 2011 So far (2)people for the rubber ones and (1)person for the poly!! Link to comment Share on other sites More sharing options...
MY1PATH Posted September 18, 2011 Share Posted September 18, 2011 (edited) my compression rod bushings are moog poly and my swaybar bushings are all energy poly. they swa bushings have been on for about 5 yrs. The compression rod bushings have been there for over a decade. Many people fail to LUBRICATE Poly during assembly. It requires a thick synthetic grease on all contact points and all areas that will squish. Energy suspension sells "energy suspension Formula 5" for this very application. It is the thickest grease I have ever used and it does not like to come off of anything. Little secret; wd40 allows it to be wiped off of most surfaces. Edited September 18, 2011 by MY1PATH Link to comment Share on other sites More sharing options...
blackspawn Posted September 18, 2011 Author Share Posted September 18, 2011 my compression rod bushings are moog poly and my swaybar bushings are all energy poly. they swa bushings have been on for about 5 yrs. The compression rod bushings have been there for over a decade. Many people fail to LUBRICATE Poly during assembly. It requires a thick synthetic grease on all contact points and all areas that will squish. Energy suspension sells "energy suspension Formula 5" for this very application. It is the thickest grease I have ever used and it does not like to come off of anything. Little secret; wd40 allows it to be wiped off of most surfaces. Thanks, I'm sure you had to buy the Formula 5 seperate,right? Link to comment Share on other sites More sharing options...
blackspawn Posted September 18, 2011 Author Share Posted September 18, 2011 Do they make a poly bushing for the lower front control arms, I couldn't find any? Link to comment Share on other sites More sharing options...
wd21overland Posted September 18, 2011 Share Posted September 18, 2011 (edited) I never found any of that when I looked. All the parts stores I checked(NAPA, O'reilly, bumper to bumper) offered no poly for my year model. My local off road shop told me that they were no longer available from ES. I just went on every auto store website you mentioned all of them sale them including napa and o'reilly. Here are the links to several sites that sale them for your pathfinder and your model year. Model year 87 thru 95 are all the same. If you have a autozone close by i also have a link down there for it also. http://ruggedrocksoffroad.com/nissan-pathfinder-wd21-r50-bushings-c-38_488.html https://www.4x4parts.com/nissan/pathfinder-pathfinder-front-bushings-c-435_377_349_741.html http://www.summitracing.com/search/brand/Energy-Suspension/Product-Line/Energy-Suspension-Rear-Control-Arm-Bushing-Sets/Make/NISSAN/Model/PATHFINDER/Year/1991/?Ns=Rank|Asc http://www.energysuspensionparts.com/products.asp?cat=Nissan+Pathfinder+4WD+1991 http://www.autozone.com/autozone/parts/Energy-Suspension-Control-Arm-Bushing-Front/1992-Nissan-Datsun-Pathfinder-4WD/_/N-j55exZ8oy1l?counter=3&itemIdentifier=357410_271550_4222_ Edited September 18, 2011 by wd21overland Link to comment Share on other sites More sharing options...
sewebster Posted September 18, 2011 Share Posted September 18, 2011 Hmm, I didn't know you had to lubricate poly... none of the moog stuff I have told me to. Guess they need better instructions! Link to comment Share on other sites More sharing options...
wd21overland Posted September 18, 2011 Share Posted September 18, 2011 (edited) Do they make a poly bushing for the lower front control arms, I couldn't find any? Yes they make them for the lower control arm also but it will only come with 2 since the other part of the lower control arm is the strut rod so look for strut rod bushings also. But energy suspension sells a complete kit with upper, lower control arm in one package. Edited September 18, 2011 by wd21overland Link to comment Share on other sites More sharing options...
blackspawn Posted September 18, 2011 Author Share Posted September 18, 2011 Yes they make them for the lower control arm also but it will only come with 2 since the other part of the lower control arm is the strut rod so look for strut rod bushings also. But energy suspension sells a complete kit with upper, lower control arm and strut rod bushings in one package. Do you have a link for me? I appreciate!!! Link to comment Share on other sites More sharing options...
wd21overland Posted September 18, 2011 Share Posted September 18, 2011 Do you have a link for me? I appreciate!!! Here are the links from energy suspension and rugged rock so either or. http://www.energysuspensionparts.com/proddetail.asp?prod=7.3102 or http://ruggedrocksoffroad.com/energy-suspension-black-front-end-control-arm-bushing-set-1987-95-nissan-pathfinder-p-2379.html Those links are for the complete upper and lower control arms for the front. And these two links are for the strut rod bushings. http://www.energysuspensionparts.com/proddetail.asp?prod=7.7106 or http://ruggedrocksoffroad.com/energy-suspension-red-front-strut-rod-bushing-set-nissan-pathfinder-1987-95-p-2384.html Link to comment Share on other sites More sharing options...
Precise1 Posted September 18, 2011 Share Posted September 18, 2011 Rubber gives more than poly so it won't feel as stiff and its wearing out should seem more progressive. Poly does need to be lubricated but should last longer in punishing applications. Perhaps it doesn't like salt? I have new poly bushings for my upper control arms and compression rods so we'll see how long they last. B Link to comment Share on other sites More sharing options...
blackspawn Posted September 18, 2011 Author Share Posted September 18, 2011 Here are the links from energy suspension and rugged rock so either or. http://www.energysuspensionparts.com/proddetail.asp?prod=7.3102 or http://ruggedrocksoffroad.com/energy-suspension-black-front-end-control-arm-bushing-set-1987-95-nissan-pathfinder-p-2379.html Those links are for the complete upper and lower control arms for the front. And these two links are for the strut rod bushings. http://www.energysuspensionparts.com/proddetail.asp?prod=7.7106 or http://ruggedrocksoffroad.com/energy-suspension-red-front-strut-rod-bushing-set-nissan-pathfinder-1987-95-p-2384.html Thank you, I really do appreciate it. Link to comment Share on other sites More sharing options...
Trogdor636 Posted September 18, 2011 Share Posted September 18, 2011 Thanks, I'm sure you had to buy the Formula 5 seperate,right? I did my sway bar bushings and end links, and it came with some lube in a little tube. Not sure if all Energy Suspension bushings come this way but mine did. Link to comment Share on other sites More sharing options...
sewebster Posted September 19, 2011 Share Posted September 19, 2011 Hmm, I didn't know you had to lubricate poly... none of the moog stuff I have told me to. Guess they need better instructions! Actually what I used from moog was apparently not polyurethane, so ignore this comment. Link to comment Share on other sites More sharing options...
MY1PATH Posted September 19, 2011 Share Posted September 19, 2011 (edited) Moog uses blue for their poly and black for their rubber. No they do not say lubricate them to in the instructions but it is a good idea. Edited September 19, 2011 by MY1PATH Link to comment Share on other sites More sharing options...
sewebster Posted September 19, 2011 Share Posted September 19, 2011 Moog uses blue for their poly and black for their rubber. No they do not say lubricate them to in the instructions but it is a good idea. Hmm. They called it thermoplastic rubber (the blue stuff). I guess you are right, that could just be their code word for polyurethane. There do exist thermoplastic polyurethanes, and I guess "rubber" can refer to "synthetic rubber" which can be pretty much anything. Perhaps I will try to slop some grease on top, better than nothing at this point. At least I know how to do it properly for next time. Link to comment Share on other sites More sharing options...
