Fuel leak-94
Trogdor636
My pathy does not spend much time in the garage with the door closed when I am not working on it, but after changing spark plugs the other day it sat in there for a good 6+ hours while I did some stuff around town. After coming back, I noticed a smell of gas, not strong, but enough to make me think there is a fuel leak somewhere. I glanced underneath, but cant say I saw much, but its 100+ degrees where I live so I cant say I spent much time really looking. Is there a common place where the fuel lines leak, maybe even the tank.
Excellent, thanks for all the advice. I know I read somewhere that the fuel lines could rust, so I was thinking there might be a common area. I'll start checking the above mentioned areas.
Normally if nothing is rotted out these trucks will leak from 2 places. Either under the hood (tighten hose clamps) or the o-ring that seals the sending unit to the tank.
which (thank god) neither are hard to get to or expensive to replace.
I know the hoses for the fuel filter are good, one of the first things I did when I bought it back in April was change it. I will check the injector rail when its not the surface of the sun outside.
geez where in norcal is it that hot recently. I live in Napa hasn't gotten over 90 in a while.
Edited by ejin4499
I'm guessing Redding, Chico or somewhere like that... :shrug:
Redding. Or "Death Valley North" as I like to call it. Its actually been sorta mild, its in the 100's a lot, but it hasnt been 110-115 yet.
I hate it when its 90 outside, so anything over that I just stay inside :rolleyes:
AAAh that makes more sense. Out there in the California prairie. We need to get together and get a run setup. :)
