FlaPather420 Posted July 31, 2011 Share Posted July 31, 2011 I have a 1995 Pathfinder 4x4 auto that won't start.Cranks over fine, Gas ok, timing belt ok, no spark at coil,replaced with new one still no spark coming out of coil. Any suggestions or help would be greatly appreciated.Email me Link to comment Share on other sites More sharing options...
Slartibartfast Posted July 31, 2011 Share Posted July 31, 2011 ... no voltage to the coil? Link to comment Share on other sites More sharing options...
FlaPather420 Posted July 31, 2011 Author Share Posted July 31, 2011 (edited) ... no voltage to the coil? voltage 11.4 DC Edited July 31, 2011 by FlaPather420 Link to comment Share on other sites More sharing options...
GrimGreg Posted August 1, 2011 Share Posted August 1, 2011 Not common, but it might be a problem with the distributor shaft, or the crank angle sensor. Does the rotor turn when you crank it? Link to comment Share on other sites More sharing options...
Kingman Posted August 1, 2011 Share Posted August 1, 2011 Sounds like the Crank Angle Position Sensor went bad. Link to comment Share on other sites More sharing options...
FlaPather420 Posted August 2, 2011 Author Share Posted August 2, 2011 Sounds like the Crank Angle Position Sensor went bad. Where is the Sensor located? Is it in the distributor? Link to comment Share on other sites More sharing options...
Kingman Posted August 2, 2011 Share Posted August 2, 2011 Yes, to replace it if it is the problem you have to replace the entire distributor. Link to comment Share on other sites More sharing options...
sewebster Posted August 2, 2011 Share Posted August 2, 2011 Yes, to replace it if it is the problem you have to replace the entire distributor. Rock auto sells the sensor for $140? You should be able to check if it is the sensor... for instance there is a test in the FSM described for checking the injectors... you take the distributor out and rotate it by hand with the key in the on position. The injectors should click in sequence as you rotate it. If they don't then your sensor is bad I guess... Link to comment Share on other sites More sharing options...
Simon Posted August 2, 2011 Share Posted August 2, 2011 Also, it could be the amplifier which is a little grey box bolted to the intake, right behind the coil. It can cause similar issues. Very easy to swap off another truck if you have the option. Link to comment Share on other sites More sharing options...
FlaPather420 Posted August 3, 2011 Author Share Posted August 3, 2011 Also, it could be the amplifier which is a little grey box bolted to the intake, right behind the coil. It can cause similar issues. Very easy to swap off another truck if you have the option. That was it! Thank for all the great info & help from other members.Why does Nissan have to make this so difficult to diagnose,but 176,000 miles later still runs strong. Link to comment Share on other sites More sharing options...
Simon Posted August 3, 2011 Share Posted August 3, 2011 Glad you got it fixed up. Link to comment Share on other sites More sharing options...
Mishka777 Posted May 16, 2023 Share Posted May 16, 2023 Simon, the little grey box, the amplifier... does it have another name? Is it a voltage amplifier? Trying to track down that part for my '95 that won't spark. Thanks! Link to comment Share on other sites More sharing options...
Frenchy Posted May 16, 2023 Share Posted May 16, 2023 Ignition module 1 Link to comment Share on other sites More sharing options...
