2milehi Posted April 20, 2011 Share Posted April 20, 2011 So I am starting to hit a ceiling with the turbo project. As suspected, I am finding that the injectors are not big enough for lots of boost. I have started searching the 'net for injectors and I am seeing a hefty price tag for bigger Nissan injectors. Anyone know where I can source used 300Z (or some other form of turboed Nissan engine) injectors at a decent price? Thanks PS I sourced STi injectors for my Subaru buildup for $150 for all 4 so I know it can be done. Link to comment Share on other sites More sharing options...
ejin4499 Posted April 20, 2011 Share Posted April 20, 2011 So I am starting to hit a ceiling with the turbo project. As suspected, I am finding that the injectors are not big enough for lots of boost. I have started searching the 'net for injectors and I am seeing a hefty price tag for bigger Nissan injectors. Anyone know where I can source used 300Z (or some other form of turboed Nissan engine) injectors at a decent price? Thanks PS I sourced STi injectors for my Subaru buildup for $150 for all 4 so I know it can be done. what about injectors for a vg33. wouldn't they be at least %10 larger than your existing ones? Should be cheap to find a good set in a junkyard. Link to comment Share on other sites More sharing options...
MY1PATH Posted April 20, 2011 Share Posted April 20, 2011 nope vg33 injectors will not do. Go to a JY and pull them off a 300zx turbo. Link to comment Share on other sites More sharing options...
Precise1 Posted April 20, 2011 Share Posted April 20, 2011 Give these guys a call, both me and a co-worker have used them with satisfaction. I got a set of 6 VG33 injectors, the fuel rails, connector lines and pressure regulator for $150... http://www.ninfiniti.com/ B Link to comment Share on other sites More sharing options...
ejin4499 Posted April 20, 2011 Share Posted April 20, 2011 nope vg33 injectors will not do. Go to a JY and pull them off a 300zx turbo. Is there a particular reason they wont work ? Not enough flow? Link to comment Share on other sites More sharing options...
2milehi Posted April 20, 2011 Author Share Posted April 20, 2011 I am needing injectors in the 500+ cc/min capacity and of high impedance flavoring. Not much luck on getting injectors only from a 300ZX. Link to comment Share on other sites More sharing options...
beastpath Posted April 20, 2011 Share Posted April 20, 2011 Here's an option for you: VG30 Fuel Rails They make it so you can use other OE injectors; They recommend Mazda RX7 injectors. Link to comment Share on other sites More sharing options...
2milehi Posted April 21, 2011 Author Share Posted April 21, 2011 Here's an option for you: VG30 Fuel Rails They make it so you can use other OE injectors; They recommend Mazda RX7 injectors. Thanks for pointing that out but the fuel rails are $180. For $40 more ($220 total) I can get 6 side feed STi injectors that fit in the factory fuel rails. Link to comment Share on other sites More sharing options...
beastpath Posted April 21, 2011 Share Posted April 21, 2011 (edited) Thanks for pointing that out but the fuel rails are $180. For $40 more ($220 total) I can get 6 side feed STi injectors that fit in the factory fuel rails. Excellent man. Can you get a pic of those injectors in the factory rails for us? What flow rate are the STi injectors at? Also will you have to use a spacer for them to fit in the plenum as they have a longer end? Edited April 21, 2011 by beastpath Link to comment Share on other sites More sharing options...
JamesRich Posted April 21, 2011 Share Posted April 21, 2011 If you have a pick a part close, Q45 injectors are 370cc. Not 500+ but still double your stock size. $5 apiece at pick a part. Not sure about the impedance though. James Link to comment Share on other sites More sharing options...
2milehi Posted April 21, 2011 Author Share Posted April 21, 2011 If you have a pick a part close, Q45 injectors are 370cc. Not 500+ but still double your stock size. $5 apiece at pick a part. Not sure about the impedance though. James This might be the answer to my question. And with bumping up fuel pressure via "tweaking" the pressure regulator that should get me enough fuel with some room to spare. Thanks! Link to comment Share on other sites More sharing options...
Kingman Posted April 21, 2011 Share Posted April 21, 2011 You could try and find some VG30DETT injectors from a wrecked car or something. So you know the socket trick with the FPR too? Link to comment Share on other sites More sharing options...
ahardb0dy Posted April 21, 2011 Share Posted April 21, 2011 Jim Wolf Technology has some bigger injectors but don't know how much they cost Link to comment Share on other sites More sharing options...
sewebster Posted April 21, 2011 Share Posted April 21, 2011 I recently paid over $200 for a stock VG30 injector Link to comment Share on other sites More sharing options...
2milehi Posted April 22, 2011 Author Share Posted April 22, 2011 You could try and find some VG30DETT injectors from a wrecked car or something. So you know the socket trick with the FPR too? You got my number I did it on a Subaru and it was pretty easy. Figure the Pf shouldn't be too different. Link to comment Share on other sites More sharing options...
Kingman Posted April 22, 2011 Share Posted April 22, 2011 (edited) They're a little more touchy, a good thwack with a socket usually bumps the pressure by around 3PSI. Did it to one car a little hard and the pressure went up from 38 base PSI to 54. Oops! Any my God, how much power are you planning on making? Stock 270cc VG30ET injectors will support 250HP, and DETT injectors can be ran to almost 400HP. Edited April 22, 2011 by Kingman Link to comment Share on other sites More sharing options...
2milehi Posted April 22, 2011 Author Share Posted April 22, 2011 They're a little more touchy, a good thwack with a socket usually bumps the pressure by around 3PSI. Did it to one car a little hard and the pressure went up from 38 base PSI to 54. Oops! Any my God, how much power are you planning on making? Stock 270cc VG30ET injectors will support 250HP, and DETT injectors can be ran to almost 400HP. I am shooting for 15 psi boost. I will never stick it on a dyno since I can road tune it pretty good. My "goal" is to be able to pull a 19' boat and camping gear up Eisenhower tunnel (11,000 feet above sea level) at 65 MPH. For the pressure regulator, I found a controllable set-up using a vice. Slowly squeeze the vice until about 2 psi over desired pressure and then release. Link to comment Share on other sites More sharing options...
2milehi Posted April 28, 2011 Author Share Posted April 28, 2011 If you have a pick a part close, Q45 injectors are 370cc. Not 500+ but still double your stock size. $5 apiece at pick a part. Not sure about the impedance though. James Looking locally, these right now don't exist. And I tried ebay and craigslist with little success. Any other recommendations? Link to comment Share on other sites More sharing options...
onefast87 Posted April 28, 2011 Share Posted April 28, 2011 http://www.fiveomotorsport.com/ I got my 83LBS(870cc) injectors for less than 450$ Link to comment Share on other sites More sharing options...
edicer2 Posted April 28, 2011 Share Posted April 28, 2011 join z31performance.com you can get some z31 fuel rails for little to nothing on there. I saw turbo 260cc injectors and rails for 40$ Link to comment Share on other sites More sharing options...
