laxman0324 Posted February 27, 2011 Share Posted February 27, 2011 So the filter change itself went fantastic, but the stupid little strap that holds it on has one of those typical 10mm rusted off bolts that Nissan loves to use. Since I couldn't fit a drill up there and did not want to grind around gas lines, I had to use tin snips and cut the rusted strap. So now I have what is pictured below. If I leave it like this it will move around a little and possibly over time come out of the strap. My only thought right now is to try and get a pair of hose clamps and try to clamp around either side of the strap, maybe diagonally. If anyone has a good idea let me know! Link to comment Share on other sites More sharing options...
Kingman Posted February 27, 2011 Share Posted February 27, 2011 Zip ties if you can make it work. Link to comment Share on other sites More sharing options...
Precise1 Posted February 27, 2011 Share Posted February 27, 2011 Yes, that should work.^ You don't want to risk wearing through with vibration though so put some foam in between the filter and what it is ziptied to... B Link to comment Share on other sites More sharing options...
MY1PATH Posted February 27, 2011 Share Posted February 27, 2011 rust already? Link to comment Share on other sites More sharing options...
laxman0324 Posted February 27, 2011 Author Share Posted February 27, 2011 rust already? I live in a heavily salted area. And look at how rusty the strap is and how not rusty a lot of the surroundings are...It seems like Nissan used cheap materials in random places on the R50. And you all think zip ties are better than hose clamps here? Link to comment Share on other sites More sharing options...
Pezzy Posted February 27, 2011 Share Posted February 27, 2011 Maybe not better, but easier to work with. Link to comment Share on other sites More sharing options...
nunya Posted February 27, 2011 Share Posted February 27, 2011 big effin hose clamp style clamp like on Ford fuel filters(or whatever size hose clamp will easily fit around it, don't know how big r50 fuel filters are). Zip-ties will work, you DO have some in the truck, right? Link to comment Share on other sites More sharing options...
snow4me Posted February 27, 2011 Share Posted February 27, 2011 Can't you get a new factory clamp and rust proof it? Link to comment Share on other sites More sharing options...
adamzan Posted February 27, 2011 Share Posted February 27, 2011 Yeah new factory clamps are like 10 dollars at the dealer. I remember helping a friend with this a couple years ago on his '98 Link to comment Share on other sites More sharing options...
Zibi Posted February 27, 2011 Share Posted February 27, 2011 The bolt on mine was rusted solid too but there was enough play that I was able to disconnect the one end and then slide it out. The new one came with some foam bits on the side and sliding it in wedged it good. I'd say zapstraps as well. Alternatively I'm sure you can replace the entire mounting bracket. I don't remember how it's held on and due to the snow I don't want to climb under my truck. But if the bracket is just a bolt on part then go grab one from a scrapper. Link to comment Share on other sites More sharing options...
Zibi Posted February 27, 2011 Share Posted February 27, 2011 I didn't even read adamzans post. If new clamps are just $10 I'd probably get one of those. Paint it with some por15 or other, cheaper rust paint before installation. Link to comment Share on other sites More sharing options...
laxman0324 Posted February 27, 2011 Author Share Posted February 27, 2011 Thanks for all the help guys...I ended up wrapping one hose clamp around the filter and another hose clamp around the bracket to lock the filter down. It doesn't seem like it will move much but if the new bracket is cheap enough I will probably get it and replace it in the next couple months. Link to comment Share on other sites More sharing options...
nunya Posted February 27, 2011 Share Posted February 27, 2011 yea... for 10 bucks, hold er togher however is working till the weather is more wrench friendly Link to comment Share on other sites More sharing options...
laxman0324 Posted February 27, 2011 Author Share Posted February 27, 2011 yea... for 10 bucks, hold er togher however is working till the weather is more wrench friendly The weather in Northern MD hasn't been too bad recently... Link to comment Share on other sites More sharing options...
nunya Posted February 27, 2011 Share Posted February 27, 2011 Shut up! I'm giving you a reason to procrastinate! Link to comment Share on other sites More sharing options...
