need a new tranny
tsailor21
ok so i need to replace the trany in my 92 and i know the 90 to 95 trannys are junk because of the oiling problem so i was wondering what other options are like couls i put a 5 speed out a a r50 model in it will it just bolt right up and plug in to all the sensors on my pathy please let me know because its starting to grind alot and it starts to nove in nutral when you let out the clutch thanks for any help tj
any 2001+ RE4R01A (found in VG powered R50's, Frontiers and Xterras) Will be your golden ticket.
Nissan never changed the Part numbers but the 2001+ are HD models.
Before you install the transmission you should Get a shift kit from SUPERIOR SHIFT. The kit is about $40 and provides some new seals and minor modification of the Valve body For crisp clean shifting and long life performance. Superior designs kits specifcally for used high mileage trannys to correct issues that were not adressed when the tranny was first designed.
any 2001+ RE4R01A (found in VG powered R50's, Frontiers and Xterras) Will be your golden ticket.Nissan never changed the Part numbers but the 2001+ are HD models.Before you install the transmission you should Get a shift kit from SUPERIOR SHIFT. The kit is about $40 and provides some new seals and minor modification of the Valve body For crisp clean shifting and long life performance. Superior designs kits specifcally for used high mileage trannys to correct issues that were not adressed when the tranny was first designed.
that would work great if it was an auto but i need to know what manual 5 speed trannys will work thanks
ps it is a 1992 se 4x4
Edited by tsailor21
ok so i can put a manual transmission out of a 96 -2000 pathfinder or pickup in my 92 pathfinder and it will bolt right up and every thing will plug right in and the slave will be the same and i can use the clutch i have in it that was put in 2 years ago and it should all work i really need to know 100precent because i am going to call the junk yard and get a price so please let me know and thanks
I believe all that is correct but I haven't done the comparison myself. Go to a site like Rock Auto and look up the part numbers for different years to see if they are the same.
Also, the 90-95 manual trannys are not junk, they just have a lubing issue due to a lower fill level. There is a TSB about overfilling to 5.1 liters.
http://www.nissanpathfinders.net/forum/index.php?showtopic=2621
All they did for the later year trannys was raise the fill hole.
Also, it may be worth simply having yours rebuilt. Ask around for a quote...
When you said garbage I assumed you meant the AUTO's.
Like stated above the MT is great and never recived any upgrades (as far as I know) I fill mine thru the sifter, Less crawling that way. The original (before knowing about the TSB) lasted 190k with the fill level too low. Thats when 5th started to go and the fragments created interference with 3rd and 1st.
o ok see mine has 225,000 on it and was rebuilt 5 years ago and im pretty shure it is about to gernade but i have to keep driving it becaues there is snow and i cant ride my cycle so ya i guess ill see about a rebuild thanks for the info and i did reds the tsb and i did overfill it throu the top but thanks for the info
FYI the 3.3 trannys have higher gear ratios than the 3.0's so your rpms at a given speed will be slightly lower.
This isn't a big differance and should not deter you its just a litte fact.
So that means that I could bolt up an Xterra AUTO tranny to my 92xe ? What do you mean with HD Models? Cuz I'm planning on changing my tranny, some what sick with it :mellow:
As I understand it, 2001+ models are Heavy Duty (HD).
I'm not sure what changes were made but I would assume it includes things like re-enforced gears, Stronger TC and stronger shift solenoids for Crisper shifting.
Yes, Mr510 posted a list of improvements IIRC. I don't understand them, but the point is, Nissan beefed up an existing tranny to handle 250hp instead of 180hp and it works.
I am seriously considering installing one (and a VG33) in my 95.
