EmptyV Posted September 22, 2010 Share Posted September 22, 2010 So I'm about to replace my rotors and pads on my '01. The last time I jacked it up was before I moved to 33's(29's) and had to use a 3" wood block to get up high enough. The jacking point on mine is 22" and I can't find any jacks(even the harbor freight 3-ton) that will go higher than 20". With the body of the jack that gives a total life of 25.75" at full extension. That doesn't seem like enough to get her off the ground. Any help is appreciated. Link to comment Share on other sites More sharing options...
01silvapathy Posted September 22, 2010 Share Posted September 22, 2010 My jack works pretty good for me and its a 3 1/4 ton jack. Ill take some measurements when I go home this weekend. Link to comment Share on other sites More sharing options...
shift220 Posted September 22, 2010 Share Posted September 22, 2010 I have a 3 ton aluminum jack. I can't remember the full lift height but I can lift it using the subframe crossmember and get both wheels off the ground no problem. With the rear, I usually use the axle for removing the tires. Link to comment Share on other sites More sharing options...
skulptr Posted September 23, 2010 Share Posted September 23, 2010 i roll my 3 ton lowboy floor jack under the front and jack up on the cross member. you do have a lift, but it shouldnt make that big of a difference. Link to comment Share on other sites More sharing options...
fleurys Posted September 23, 2010 Share Posted September 23, 2010 under the sub frame for the front, under the diff for the rear. Link to comment Share on other sites More sharing options...
DanAK Posted September 23, 2010 Share Posted September 23, 2010 if you cant jack it up that just means you have some awesome clearance oh, it also means you will be calling a tow truck the next time you get a flat. Link to comment Share on other sites More sharing options...
01silvapathy Posted September 23, 2010 Share Posted September 23, 2010 Most of the time I have more problems with the jackstands than I do jacking up the truck. I usually wind up putting the jackstands on cinderblocks or cut railroad ties And yes, r50's do have alot of clearance! My pathy with the 2in lift on 285-75-16 (33) has more ground clearance than my buddies 6.5in lifted chevy on 35's. This is because he has a massive drop bracket in the front and our rigs dont since is about as high as you can lift without doing a sfd Link to comment Share on other sites More sharing options...
Northernpathy Posted September 23, 2010 Share Posted September 23, 2010 My standard 2.75ton jack brings it up off the ground without any problems. Though I only have 31's on the truck. Link to comment Share on other sites More sharing options...
XPLORx4 Posted September 23, 2010 Share Posted September 23, 2010 (edited) Before I bought my hydraulic scissors lift, I jacked my truck with a floor jack under the front subframe crossmember or under the rear diff, in combination with jack stands. I have also placed the floor jack beneath the ball joint before. If I needed to use the stock jacking location (just behind the front wheel well) I placed a couple of short 4x4 blocks of wood on top of the jack. For emergency use now, I use a high-lift jack, placed under my sliders. Edited September 23, 2010 by XPLORx4 Link to comment Share on other sites More sharing options...
02silverpathy Posted September 24, 2010 Share Posted September 24, 2010 Hopefully not a , but how do you guys use your hi-lift? where do you locate it on the truck? Link to comment Share on other sites More sharing options...
SilverPath Posted September 24, 2010 Share Posted September 24, 2010 Sliders, though if you have a built bumper I'm sure you could jack from under the front or rear. Link to comment Share on other sites More sharing options...
EmptyV Posted September 24, 2010 Author Share Posted September 24, 2010 Well I measured wrong, my starting jacking height is around 17" and my old jack had a max lift of 14.25". I ended up buying a 3 ton jack from harbor freight which was on sale for $60. It is enough to get the tires off the ground which allowed me to replace my rotors and pads today, woohoo! Thanks guys! In 2 weeks I'll be ordering the Trail Gear 67" Rock sliders. I'll be enlisting my welding buddy because they have to be cut and welded on. I envy the guys that can fab up metal, definitely an art. Link to comment Share on other sites More sharing options...
01silvapathy Posted September 25, 2010 Share Posted September 25, 2010 Well I measured wrong, my starting jacking height is around 17" and my old jack had a max lift of 14.25". I ended up buying a 3 ton jack from harbor freight which was on sale for $60. It is enough to get the tires off the ground which allowed me to replace my rotors and pads today, woohoo! Thanks guys! In 2 weeks I'll be ordering the Trail Gear 67" Rock sliders. I'll be enlisting my welding buddy because they have to be cut and welded on. I envy the guys that can fab up metal, definitely an art. Pics of how you do the trail gear sliders would be greatly appreceated Link to comment Share on other sites More sharing options...
Tungsten Posted September 25, 2010 Share Posted September 25, 2010 The jacking thread has been Link to comment Share on other sites More sharing options...
