rocknforchrist Posted May 23, 2010 Share Posted May 23, 2010 (edited) Hey fellas. Just had some questions. I've searched old threads and it seems my AT pathfinder needs to have a better trans cooler put on. I know this is something I could install but I'd like some info on installation, and maybe some pictures of an install. Also where should I look for a t cooler and how much is a decent price. My new pathfinder is frame rust free and I look forward to fixing some minor things on it to get it running well. Edited May 23, 2010 by rocknforchrist Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 23, 2010 Share Posted May 23, 2010 there was a big thread about the tranny coolers and someone is using 2 out of a ford car but I can't find it and am looking for the thread also. Anyone know where it is please?? Link to comment Share on other sites More sharing options...
Dowser Posted May 23, 2010 Share Posted May 23, 2010 Here's one on reviews to give you a suggestion for what to buy and how much you will be looking at spending. Review And Hands down one of the best how to's I've looked at for a person that doesnt know what to do is from Doctor Bills Thread. I have this one Bookmarked because its good to use for reference for anyone attempting a Timing belt job and more. Once again, Nice work Doctor Bill. PLEASE leave all your photo's up wherever you have them posted forever. Doctor Bill's AT Transmission cooler starts on page 3ish. Good luck and thank those that have spent their time to make a good how to for you. Link to comment Share on other sites More sharing options...
swapdip Posted May 23, 2010 Share Posted May 23, 2010 +1 on DoctorBill's authority, altho you don't need to purchase a brand new cooler like he did. I pulled a tranny cooler out of a Ford Explorer in the junkyard, spent about 8 bucks on 2 3' lengths of transmission fluid line, and rigged mine up in front of my radiators, works great. It's actually a fairly simple procedure, check out the writeup and ask if you have any further questions. Link to comment Share on other sites More sharing options...
rocknforchrist Posted May 24, 2010 Author Share Posted May 24, 2010 WOW! Thanks Dr.Bill for that info...and the pics, really a great thread! If this much info was given on more things i wouldn't hesitate working on anything. And hailing from the "ShowMe" state pictures help...HarHar! Link to comment Share on other sites More sharing options...
RJSquirrel Posted June 2, 2010 Share Posted June 2, 2010 http://www.nissanpathfinders.net/forum/index.php?showtopic=23236 Link to comment Share on other sites More sharing options...
silverton Posted June 19, 2010 Share Posted June 19, 2010 (edited) Just installed mine today, meant to get the one rated at 16k GVWR but accidentally got the 12k one, it should be well enough. As the rig only weighs 4200 and I don't think I'll be towing 8k pounds of anything. And pics of my install, I put it between the AC condenser and the radiator, there was just enough room for it to fit! I ran the lines under the radiator, again, just enough room for that. Edited June 19, 2010 by silverton Link to comment Share on other sites More sharing options...
Kingman Posted June 19, 2010 Share Posted June 19, 2010 Same cooler as on my old Pathfinder. Never mind mine was an 18,000 GVW but it was somehow cheaper than the 16,000 GVW one. Link to comment Share on other sites More sharing options...
adamzan Posted June 21, 2010 Share Posted June 21, 2010 Wow that is a small cooler! Link to comment Share on other sites More sharing options...
RJSquirrel Posted June 22, 2010 Share Posted June 22, 2010 Silverton: That cooler is not nearly big enough to do the job adequately by itself. Please see the thread I linked in one of my earlier posts on this thread. No Joke. You need to either get a much larger one (or two) coolers, especially since you are installing it behind the AC condenser, which reduces its efficiency, and re-hook up the radiator transmission cooler into the loop before the fluid goes to the coolers. You upgraded your transmission, it would be a shame to burn it out on the first long climb you do this summer. Link to comment Share on other sites More sharing options...
adamzan Posted June 22, 2010 Share Posted June 22, 2010 Yeah an 18,000 GVW should be sufficient. Link to comment Share on other sites More sharing options...
Tungsten Posted June 22, 2010 Share Posted June 22, 2010 run it inline with the radiator or get another cooler and piggy back it i have a 24,000 GVW cooler and i run it inline with the stock tube through the radiator i do have a new radiator though Link to comment Share on other sites More sharing options...
silverton Posted June 22, 2010 Share Posted June 22, 2010 I may add one later on down the road, just from what is being suggested here. But I will state, column heat is down to nil, about that of cabin temp, if not less. where as before, the console was very warm to the touch. Link to comment Share on other sites More sharing options...
Kingman Posted June 22, 2010 Share Posted June 22, 2010 run it inline with the radiator or get another cooler and piggy back it i have a 24,000 GVW cooler and i run it inline with the stock tube through the radiator i do have a new radiator though Do not run it inline with the radiator, you'd effectively be in the same situation as you would be without the aftermarket cooler. Always bypass the stock Nissan cooler... Unless like you said, you have a brand new radiator. It's not worth the risk to use an old original cooler in a new set up. Link to comment Share on other sites More sharing options...
Indigent Posted July 7, 2010 Share Posted July 7, 2010 X2 on what kingman said. Nissan coolers suck, and I wouldn't trust even replacement ones. Put the tranny cooler out in front of the AC and Radiator. Link to comment Share on other sites More sharing options...
OldSlowReliable Posted July 7, 2010 Share Posted July 7, 2010 I put mine out in front....I paid for an 18k or something but they sent me a 21 or 22k....fine w/me! I ran my cooler lines through the bumper bracket holes in the support, and they are nice and out of the way, safe from danger there...installed a cheapo HF gauge which works flawlessly, and gotta change the fluid one more time yet. That cooler doesn't look too small to me....looks like the same size as mine (although I have a fin type, not tube and fin) Link to comment Share on other sites More sharing options...
tmoore4512 Posted July 7, 2010 Share Posted July 7, 2010 I did not have enough room out front to mount mine, so I sandwiched it between the evaporator and the radiator. Works great. I do not feel the extreme heat coming from the hump as I used too... OSR, where did you mount your gauge? Got any pics? Link to comment Share on other sites More sharing options...
RJSquirrel Posted July 7, 2010 Share Posted July 7, 2010 I put mine out in front....I paid for an 18k or something but they sent me a 21 or 22k....fine w/me! I ran my cooler lines through the bumper bracket holes in the support, and they are nice and out of the way, safe from danger there...installed a cheapo HF gauge which works flawlessly, and gotta change the fluid one more time yet. That cooler doesn't look too small to me....looks like the same size as mine (although I have a fin type, not tube and fin) The fin types are supposedly more efficient radiators than the tube&fin designs, so for a given size, you get more heat rejection. Also, when the cooler is mounted behind the AC condenser, its de-rated to 70% of the stated capacity it would have if it were in the front getting the coolest air possible. Link to comment Share on other sites More sharing options...
Dowser Posted July 7, 2010 Share Posted July 7, 2010 I've also been wondering about Radiators lately. From what I understand, The Stock Tranny Cooler is built into the Radiator unit for our vehicles and I've been wondering if there are different Rads for Manual and Auto's. If they are different then perhaps the Manual versions are a slimmer design sparing a little more room to mount. This is all speculation of course. Can anyone Confirm? Link to comment Share on other sites More sharing options...
Precise1 Posted July 7, 2010 Share Posted July 7, 2010 I did not have enough room out front to mount mine, so I sandwiched it between the evaporator and the radiator. Works great. I do not feel the extreme heat coming from the hump as I used too... OSR, where did you mount your gauge? Got any pics? Here is a thread for that... http://www.nissanpathfinders.net/forum/index.php?showtopic=24503 I've also been wondering about Radiators lately. From what I understand, The Stock Tranny Cooler is built into the Radiator unit for our vehicles and I've been wondering if there are different Rads for Manual and Auto's. If they are different then perhaps the Manual versions are a slimmer design sparing a little more room to mount. This is all speculation of course. Can anyone Confirm? It is the same radiator for the manual and AT trannys. If you have an MT, you just ignore or plug the two bottom fittings. Sorry, no dice. B Link to comment Share on other sites More sharing options...
tmoore4512 Posted July 7, 2010 Share Posted July 7, 2010 And Bernard comes through again... Link to comment Share on other sites More sharing options...
adamzan Posted July 8, 2010 Share Posted July 8, 2010 Man after having the cooler in front of the a/c condenser I have noticed it made my a/c not work as well as it used to Link to comment Share on other sites More sharing options...
Precise1 Posted July 8, 2010 Share Posted July 8, 2010 LOL I have 2.5 solutions... B Link to comment Share on other sites More sharing options...
tmoore4512 Posted July 9, 2010 Share Posted July 9, 2010 Precisely why mine is sandwiched between the coils... Link to comment Share on other sites More sharing options...
Tungsten Posted July 9, 2010 Share Posted July 9, 2010 Here is a thread for that... http://www.nissanpathfinders.net/forum/index.php?showtopic=24503 It is the same radiator for the manual and AT trannys. If you have an MT, you just ignore or plug the two bottom fittings. Sorry, no dice. B No, the MT radiator does not have the two bottom fittings but it is the same radiator. Link to comment Share on other sites More sharing options...
