canadian4wheeler Posted January 31, 2010 Share Posted January 31, 2010 I have a 95 Pathfinder with a automatic transmission. And I currently have 31" tires but I find they bottom out at times when I'm out wheeling. What I'm wondering is if I can install a body lift on it? Even though it has a automatic trans.? If not can anyone help me on solutions for getting a higher ride hight/ lift. Without doing a full on suspension lift, since I'm on a budget. thanks Link to comment Share on other sites More sharing options...
MY1PATH Posted January 31, 2010 Share Posted January 31, 2010 yes you can! the AT shifter cables will reach up to a 3" BL with no modifacation. then you will be less likely to hit your fenders with your tires Link to comment Share on other sites More sharing options...
ac92pathfinder Posted January 31, 2010 Share Posted January 31, 2010 why are some people have problems with there 31's hitting the fender? Link to comment Share on other sites More sharing options...
nunya Posted January 31, 2010 Share Posted January 31, 2010 why are some people have problems with there 31's hitting the fender? Torsion bar sag... Link to comment Share on other sites More sharing options...
PATHRIDER Posted January 31, 2010 Share Posted January 31, 2010 (edited) hard wheeling also accounts to that and rim offset Edited January 31, 2010 by PATHRIDER Link to comment Share on other sites More sharing options...
R3DN1CK Posted January 31, 2010 Share Posted January 31, 2010 why are some people have problems with there 31's hitting the fender? agreed... the 31x10.50 was an optional stock size tire, and if it is torsion bar sag, wouldn't it be easier and cheap to readjust the bars? Link to comment Share on other sites More sharing options...
canadian4wheeler Posted January 31, 2010 Author Share Posted January 31, 2010 Ok cool, so then I guess my shifter would just shorten by three inches and that would really be it for things that would change. Other than extending gas filler and moving bumpers. Link to comment Share on other sites More sharing options...
MY1PATH Posted January 31, 2010 Share Posted January 31, 2010 4x4parts.com I hit the fender when flexing or bottoming out but just barely. I think 1" BL will remedy that for me you have to call and request those but its only $100. most ppl just do a 2" or 3" Link to comment Share on other sites More sharing options...
canadian4wheeler Posted February 1, 2010 Author Share Posted February 1, 2010 4x4parts.com I hit the fender when flexing or bottoming out but just barely. I think 1" BL will remedy that for me you have to call and request those but its only $100. most ppl just do a 2" or 3" Yeah I'm gonna end up doing a 3" lift. Cause I found a kit online and it's only $150.00 Link to comment Share on other sites More sharing options...
PATHRIDER Posted February 1, 2010 Share Posted February 1, 2010 Yeah I'm gonna end up doing a 3" lift. Cause I found a kit online and it's only $150.00 Redpath has a set for $100 I think..Check for sale section Link to comment Share on other sites More sharing options...
Ontariopathie Posted February 2, 2010 Share Posted February 2, 2010 I just did a 3" lift on mine, there is a couple of things to do,power steering pump lines,fuel lines,lower rad hose,upper rad hose,fan shroud,if you have a bush bar you need to relocate that,the bumper bracket relocation tabs loosen and drop. I am NOT trying to make this sound like a lost cause but I wanted you to know its a little bit of work. Also put the rear bolts in before the rest or it's a B***h to get them in. Link to comment Share on other sites More sharing options...
Precise1 Posted February 2, 2010 Share Posted February 2, 2010 Honestly, it sounds like a standard pathfinder lift... B Link to comment Share on other sites More sharing options...
Astroc2002 Posted February 2, 2010 Share Posted February 2, 2010 I want to do a 3" body lift to my Pathfinder, but I heard on another forum that when doing a 3" body lift the four-wheel drive shifter can't shift into four low, because the shifter ends up hitting the center console when trying to shift between neutral and four low because the shifter is shorter when doing a 3" body lift. Has anyone here experienced this problem with their Pathfinder? Because I'd like to know if this a true problem. Link to comment Share on other sites More sharing options...
Precise1 Posted February 2, 2010 Share Posted February 2, 2010 *sigh* Did the Admins disable the search function again?? Yes, what you read is true. The 3 things to do is install a hard body shifter (different shape and length), heat and bend your existing shifter or notch the floor to make some clearance. B Link to comment Share on other sites More sharing options...
RedPath88 Posted February 3, 2010 Share Posted February 3, 2010 Redpath has a set for $100 I think..Check for sale section Nope not mine, I just posted it for others. "If" it is still available, I imagine the craigslist add I linked to is expired by now. *Sigh*Did the Admins disable the search function again?? B You would think so, but no... it still works perfectly Link to comment Share on other sites More sharing options...
Astroc2002 Posted February 8, 2010 Share Posted February 8, 2010 *sigh* Did the Admins disable the search function again?? Yes, what you read is true. The 3 things to do is install a hard body shifter (different shape and length), heat and bend your existing shifter or notch the floor to make some clearance. B OK, I just wanted to clear that piece up before I do get the 3" Calamini SL and a 3" BL on my Pathfinder. Thanks. Link to comment Share on other sites More sharing options...
