ditchdiggerjcf Posted January 22, 2010 Share Posted January 22, 2010 My truck had developed another exhaust leak around the manifolds. My mechanic just got through rebuilding my heads, and now this. I hope he can get it right this time. Link to comment Share on other sites More sharing options...
Precise1 Posted January 22, 2010 Share Posted January 22, 2010 Did he replace the studs with the stronger updated units or did he just retorque the old, prone to breaking ones?? B Link to comment Share on other sites More sharing options...
ditchdiggerjcf Posted January 22, 2010 Author Share Posted January 22, 2010 Did he replace the studs with the stronger updated units or did he just retorque the old, prone to breaking ones?? B I didn't know they made a stronger updated one. To answer your question, probably not Link to comment Share on other sites More sharing options...
Precise1 Posted January 22, 2010 Share Posted January 22, 2010 Ok, which may explain why there is still an issue. I'll dig up the appropriate link in the morning (too tired now) and you can show it to your mechanic. If he doesn't give it credence, go find another mechanic... Oh, Permatex copper RTV does wonders for exhaust gaskets... B Link to comment Share on other sites More sharing options...
ditchdiggerjcf Posted January 22, 2010 Author Share Posted January 22, 2010 Ok, which may explain why there is still an issue. I'll dig up the appropriate link in the morning (too tired now) and you can show it to your mechanic. If he doesn't give it credence, go find another mechanic... Oh, Permatex copper RTV does wonders for exhaust gaskets... B thanks Link to comment Share on other sites More sharing options...
Precise1 Posted January 22, 2010 Share Posted January 22, 2010 Here, this has the part # information in it, the studs should be the same as for the zx turbo. The stock studs are known to break so any time the heads/manifolds are removed, it is highly recommended to replace them with the stronger versions. I upgraded to harder bolts but I need to check if they are still torqued properly... http://www.nissanpathfinders.net/forum/index.php?showtopic=21832&view=&hl="exhaust studs"&fromsearch=1 B Link to comment Share on other sites More sharing options...
FUELER Posted January 22, 2010 Share Posted January 22, 2010 Precise - do those zx studs go right in the stock holes with no modification? Link to comment Share on other sites More sharing options...
ditchdiggerjcf Posted January 23, 2010 Author Share Posted January 23, 2010 Precise - do those zx studs go right in the stock holes with no modification? that thread had a bit in it about NAPA studs. Are those worth a flip? Link to comment Share on other sites More sharing options...
Precise1 Posted January 24, 2010 Share Posted January 24, 2010 Yes FUELER, they do. They are the same pitch (M8x1.25) studs, just a different material/hardness/grade. Remember though, this is only for WD21s, the R50s (and cousins) have 10mm studs and generally don't have the breakage issue. DD, I have no idea, I have not used them. If the member that posted that is active, PM him or even email if there is an address. Like I said, I simply used bolts as paying $75 for hardware is offensive. Some people have reported problems of them backing out/loosening up and I have yet to check mine. Too much rain... B Link to comment Share on other sites More sharing options...
BenStoked Posted January 25, 2010 Share Posted January 25, 2010 What length bolts did you use? think a split washer would prevent backing out? I have also heard of people buying allthread, cutting it down, and using that. not sure how well it would work, since it seems pretty soft compared to a hardened bolt/stud. Link to comment Share on other sites More sharing options...
ditchdiggerjcf Posted January 25, 2010 Author Share Posted January 25, 2010 What length bolts did you use? think a split washer would prevent backing out? I have also heard of people buying allthread, cutting it down, and using that. not sure how well it would work, since it seems pretty soft compared to a hardened bolt/stud. Allthread would be a huge no-no Link to comment Share on other sites More sharing options...
Precise1 Posted January 25, 2010 Share Posted January 25, 2010 What length bolts did you use? think a split washer would prevent backing out? I have also heard of people buying allthread, cutting it down, and using that. not sure how well it would work, since it seems pretty soft compared to a hardened bolt/stud. Allthread would be a huge no-no Exactly. Just forget you thought that and all will be well. Here is a discussion about the exhaust hardware. Not sure who is wrong, but most are probably right. Read up and make a choice, or just ask what want. It doesn't seem to be a finished topic... http://www.nissanpathfinders.net/forum/index.php?showtopic=23631&st=0 B Link to comment Share on other sites More sharing options...
RedPath88 Posted January 25, 2010 Share Posted January 25, 2010 that thread had a bit in it about NAPA studs. Are those worth a flip? DD, I have no idea, I have not used them. If the member that posted that is active, PM him or even email if there is an address. Like I said, I simply used bolts as paying $75 for hardware is offensive. Some people have reported problems of them backing out/loosening up and I have yet to check mine. Too much rain...B I used replacement studs from NAPA and am just about to hit 80K since they were installed. So far, so good Link to comment Share on other sites More sharing options...
MY1PATH Posted January 25, 2010 Share Posted January 25, 2010 Allthread would be a huge no-no x3 Link to comment Share on other sites More sharing options...
ditchdiggerjcf Posted January 26, 2010 Author Share Posted January 26, 2010 I used replacement studs from NAPA and am just about to hit 80K since they were installed. So far, so good I'll call NAPA tomorrow. thanks Link to comment Share on other sites More sharing options...
