300zx calipers?
ImportDoc
there is interchange-abily of calipers and a few rotors from several vehicles...
I don't remember the exact combinations but really once I went rear disc I was plenty satified with the braking. My next step will be better lines and possibly stillen rotors with ebc greenstuf pads.
dono the plus or minus of this but if your front brakes are 2 piston they are plastic pistons and the single piston calipers are metal piston.
you can make any caliper work if u get the right rotor and its spaced right. i put z32 brakes on my z31 300zx massive massive upgrade but i also put 350z track rotors on also
Edited by edicer2
thanks for the input. i only ask seeing as if 300z's are 4 piston in front and 2 piston rear. my 95 has rear disc already and i am going to be swappin out rotors and such 2 get a lil better braking but i was just inquiring if any1 knew of this being done. id love to get some more feed back about the master cylinder upgrade...thanks again
