sencaw Posted November 28, 2009 Share Posted November 28, 2009 (edited) Hey all! Got my alternator done today and now with the knocking and grinding sound gone, I noticed a new noise that could not be heard over the old rattlin alt. The noise emanates from this thing and sounds like a coffee maker percolating, it that normal or should I do something? Item in question pictured below: and as always - thank you in advance! Edited November 28, 2009 by sencaw Link to comment Share on other sites More sharing options...
Precise1 Posted November 28, 2009 Share Posted November 28, 2009 Carbon canister for emissions, I'm pretty sure. I have a 95 so I don't know if our units are the same. There shouldn't be any liquid in it. What kind of liquid is it?? At least drain, if not replace it. Are you sur the vacuum diaphram is finctioning correctly?? Maybe that is responsible?? B Link to comment Share on other sites More sharing options...
sencaw Posted November 28, 2009 Author Share Posted November 28, 2009 Carbon canister for emissions, I'm pretty sure. I have a 95 so I don't know if our units are the same. There shouldn't be any liquid in it. What kind of liquid is it?? At least drain, if not replace it. Are you sur the vacuum diaphram is finctioning correctly?? Maybe that is responsible?? B Yeah, beats me if its working properly or not - no sure if there is liquid in it, just sounds like its gurgling - wasnt sure if that was normal or not... Link to comment Share on other sites More sharing options...
Precise1 Posted November 29, 2009 Share Posted November 29, 2009 Gurgling is not normal, I'm sure of that. Time to check the hoses and canister for leaks and such... B Link to comment Share on other sites More sharing options...
RedPath88 Posted November 29, 2009 Share Posted November 29, 2009 Yes that is the Canister, but are you positive that the gurgling is coming from it and not the AIV, the thing in the lower right hand corner of you picture. That is, in my experience were a gurgling sound normally comes from. They often rust out, due to the exhaust gases that run through them. Run along the outer edge of it and see if it is solid, by the pic I can see rust on it already. Check along the bottom of it a little extra, if it does have water in it, then that is where it is likely to rust the most I've replaced mine twice with wrecking yard units (and the AIV Case, located behind the headlight once) Both times it was gurgling. Link to comment Share on other sites More sharing options...
MY1PATH Posted November 29, 2009 Share Posted November 29, 2009 (edited) x2 that thing on the right side of the picture make sounds like a perculator. and mine needs replaced! Edited November 29, 2009 by MY1PATH Link to comment Share on other sites More sharing options...
Alkorahil Posted November 30, 2009 Share Posted November 30, 2009 X3 here. Link to comment Share on other sites More sharing options...
Kingman Posted November 30, 2009 Share Posted November 30, 2009 Yup. My old truck did that and it was obnoxious. Thankfully my new one isn't rusted out so it stays quiet. Link to comment Share on other sites More sharing options...
sencaw Posted December 1, 2009 Author Share Posted December 1, 2009 OK thanks guys, case closed then. Link to comment Share on other sites More sharing options...
