bigred07 Posted August 19, 2009 Share Posted August 19, 2009 I did something similar a while back. Not really sure why I bothered with a grade 8 bolt though so having it that way, it wont let you put the little plastic cover pieces on will it? Link to comment Share on other sites More sharing options...
nige Posted August 20, 2009 Share Posted August 20, 2009 (edited) the hammock is nice if the weather co-operates. you just have to find a tree or post to park next to. This hammock from Hennessy Hammocks is freakin amazing. It has a bug shield and rain fly that can collect rainwater into bottles for you and hold the fly down in a storm. some of them hold up to 350 lbs, so 2 lighter people could sleep in it, or 1 person and your bag can stay dry off the ground Edited August 20, 2009 by nige Link to comment Share on other sites More sharing options...
Zibi Posted August 20, 2009 Share Posted August 20, 2009 so having it that way, it wont let you put the little plastic cover pieces on will it? I could put them in, they fit fine, I just don't. No need for them and they're already cracking with age, plus I'd likely just lose them at some point when taking out the benches. and jeenyus, thats easy to say when you aren't face to face with a full grown grizzly Big as fskc, they can run, swim, and climb faster than you. Having said that I'm more worried about cougars in the bush, just because they're sneaky bastards. But I'll still @!*% myself if I ever find myself between a bear and her cub. Link to comment Share on other sites More sharing options...
Kyle94 Posted September 26, 2010 Share Posted September 26, 2010 ok, so i want to do this mod, but my stepdad doesnt think i can drill through the factory pin on the bracket... Link to comment Share on other sites More sharing options...
MY1PATH Posted September 26, 2010 Share Posted September 26, 2010 Of course you can, smack it with a center punch and just drill the head off. or take it off with a dremel cutting wheel down the center and pull bot sides out. Its just mild steel, not un-obtainium or anything lol Link to comment Share on other sites More sharing options...
beastpath Posted September 26, 2010 Share Posted September 26, 2010 not un-obtainium or anything lol hahahaha! Link to comment Share on other sites More sharing options...
DavefromOZ Posted September 26, 2010 Share Posted September 26, 2010 If you have a steady hand, it can be done with a 4" angle grinder, which is what I used. Link to comment Share on other sites More sharing options...
Kyle94 Posted September 27, 2010 Share Posted September 27, 2010 well. got it done. took all four brackets off the seats, and put one in the vice at a time and grinded the end with the "X" off. then found some bolts in the massive pile we have. then went to ACE Hardware and picked up some wing nuts for the bolts and another bolt cause we didnt have a matching set of four bolts. now i just have to find a twin or full sized air mattress (or not) and put in the pathy... Link to comment Share on other sites More sharing options...
