Astroc2002 Posted July 31, 2009 Share Posted July 31, 2009 About a week ago my Automatic Transmission Temperature Light / E-Brake Light / Battery Light came on while I was driving and later would fade. Now its on all the time and I'm concerned it might be the ECU or a major sensor is tripping. If any body knows what this means please get back to me A.S.A.P. Thanx JB Link to comment Share on other sites More sharing options...
nunya Posted July 31, 2009 Share Posted July 31, 2009 Actually kind of sounds like an alternator problem. Check to make sure your charging, if not it will kick on a bunch of warning lights(don't know if a 94 has a dash gauge but I think most parts stores will check for free for you to see if your charging) Link to comment Share on other sites More sharing options...
adamzan Posted August 1, 2009 Share Posted August 1, 2009 Those lights are the code for dead alternator. Link to comment Share on other sites More sharing options...
94extreme Posted August 1, 2009 Share Posted August 1, 2009 could be bad ground or a short somewhere too but definitely check to see if the alt is charging first. Link to comment Share on other sites More sharing options...
Alkorahil Posted August 1, 2009 Share Posted August 1, 2009 Yep, alternator related. Link to comment Share on other sites More sharing options...
headpeace Posted August 1, 2009 Share Posted August 1, 2009 yep, mine did the same thing about 3 weeks ago, check your alt before you get stuck somewhere Link to comment Share on other sites More sharing options...
edicer2 Posted August 1, 2009 Share Posted August 1, 2009 (edited) yeah its either your alty. battery or a bad ground. when its running check with a volt meter to see if your getting 14.5v or so to the battery. if your not then its a bad alty Edited August 1, 2009 by edicer2 Link to comment Share on other sites More sharing options...
