LostNcrRanger Posted June 19, 2009 Share Posted June 19, 2009 Hey guys, Just wondering if anyone's thrown a Transmission temperature gauge in their pathy,and if so can you share pics? Thanks in advance. Link to comment Share on other sites More sharing options...
GrimGreg Posted June 19, 2009 Share Posted June 19, 2009 I don't have pics of mine, but I just put a brass T fitting into the line going into the cooler from the tranny. Had to braze a wire to the fitting to ground the sensor out though. Link to comment Share on other sites More sharing options...
LostNcrRanger Posted June 19, 2009 Author Share Posted June 19, 2009 From what i've heard it's not difficult,i just wanna put one in so i don't nuke my tranny. where'd you mount your gauge? Link to comment Share on other sites More sharing options...
94extreme Posted June 19, 2009 Share Posted June 19, 2009 yeah GG, where are the pics man. i was about to say that no one here as done it as i surely don't recall any threads about this. good luck kali. if GG doesn't, you must up some pics. Link to comment Share on other sites More sharing options...
GrimGreg Posted June 20, 2009 Share Posted June 20, 2009 See what I can do. Here is the one I bought: http://www.jegs.com/p/B-M/B-M-Transmission...748099/10002/-1 Link to comment Share on other sites More sharing options...
Tungsten Posted June 26, 2009 Share Posted June 26, 2009 Isn't there an A/T temp warning light on the dashboard? I have one and maybe you can somehow use that circuit to get an actual reading. Link to comment Share on other sites More sharing options...
GrimGreg Posted June 26, 2009 Share Posted June 26, 2009 Isn't there an A/T temp warning light on the dashboard? I have one and maybe you can somehow use that circuit to get an actual reading. Basically that is like a tilt light on a pinball machine, if it comes on, the tranny is already toasted. Link to comment Share on other sites More sharing options...
Precise1 Posted June 26, 2009 Share Posted June 26, 2009 I don't know at what temp the AT Temp light is supposed to go on, but I never trust idiot lights. Like GG said, usually by the time they trigger you have a real issue. Gauges are the way to go. I plan to install a Tranny filter and temp gauge along with volt meter, oil pressure and oil or coolant temp. B Link to comment Share on other sites More sharing options...
Indigent Posted June 27, 2009 Share Posted June 27, 2009 A friend of a friend in Japan did a tranny temp guage along with a whole bunch of other cool stuff on his terrano. Check it (japanese, try google translate or something): http://www.u-shonan.com/myterrano/Soup-up/chapter-11.htm Link to comment Share on other sites More sharing options...
kiwipete Posted June 27, 2009 Share Posted June 27, 2009 A friend of a friend in Japan did a tranny temp guage along with a whole bunch of other cool stuff on his terrano. Check it (japanese, try google translate or something):http://www.u-shonan.com/myterrano/Soup-up/chapter-11.htm http://translate.google.com/translate?js=n...history_state0= Link to comment Share on other sites More sharing options...
GoPathyGo Posted June 28, 2009 Share Posted June 28, 2009 After I smelled burning oil, decided to grab a transfer case temp gauge and a tranny temp gauge. I think the only diff between a "Transmission Temp Gauge" and a "Transfer Case Temp Gauge" is the labeling. I like the idea of getting a T-connecter version for the sending unit. Avoids drilling into the tranny. Could you use a drain plug, too ? Link to comment Share on other sites More sharing options...
fleurys Posted June 28, 2009 Share Posted June 28, 2009 After I smelled burning oil, decided to grab a transfer case temp gauge and a tranny temp gauge. I think the only diff between a "Transmission Temp Gauge" and a "Transfer Case Temp Gauge" is the labeling. I like the idea of getting a T-connecter version for the sending unit. Avoids drilling into the tranny. Could you use a drain plug, too ? Last time I read something about your tc and transmission oil change, you said the 2 were sharing the same oil...(Which is not true)... I'm not sure if you figured it out..but if you did not, is it possible that you flushed the tc, then the trans than refilled the trans, leaving the tc empty thinking it would filled it too?? S. Link to comment Share on other sites More sharing options...
GoPathyGo Posted June 28, 2009 Share Posted June 28, 2009 Last time I read something about your tc and transmission oil change, you said the 2 were sharing the same oil...(Which is not true)... I'm not sure if you figured it out..but if you did not, is it possible that you flushed the tc, then the trans than refilled the trans, leaving the tc empty thinking it would filled it too?? S. Ha! Fortunately not. Turns out I never changed the t-case oil. Just the A/T oil. That was 'cause I never found the t-case drain and fill plugs. Today I finally found them - after scraping off crap and using a flashlight. Apparently my eyes are losing it... So there was definitely fluid in it when I smelled the burning. They do use the same fluid, just not the same drain and fill plugs. I was confused on the drain and fill thing. Link to comment Share on other sites More sharing options...
