mikeinIdaho Posted February 23, 2009 Share Posted February 23, 2009 I ran the ecu codes and got no codes My truck runs great until it comes into temperature. While this makes it sound like an o2 sensor, i unplugged it with no change. also I recently dumped some Marvel Mystery Oil in the fuel tank-so could this be a cause of rough running after coming up to temp? Link to comment Share on other sites More sharing options...
burton8it Posted February 23, 2009 Share Posted February 23, 2009 I ran the ecu codes and got no codes My truck runs great until it comes into temperature. While this makes it sound like an o2 sensor, i unplugged it with no change. also I recently dumped some Marvel Mystery Oil in the fuel tank-so could this be a cause of rough running after coming up to temp? My 92 XE did that would run normal up until running temp. mind you i did take mine swimming but it was my mass airflow that was shot Link to comment Share on other sites More sharing options...
mikeinIdaho Posted February 23, 2009 Author Share Posted February 23, 2009 I hope its not the MAF! It is driveable, up through the gears, but if you are over geared-like rolling along 35mph in 4th-it kinda chugs along until the RPMs come up. could this be my O2 sensor? Change plugs/wires or run this tank of fuel with the Marvel in it and start over? Link to comment Share on other sites More sharing options...
MY1PATH Posted February 24, 2009 Share Posted February 24, 2009 try cleaning your MAF; theres an article in the how-to's. run the tank to empty and re-fill w/o the marvel and see what that does. Link to comment Share on other sites More sharing options...
Kingman Posted February 24, 2009 Share Posted February 24, 2009 I ran Marvel through mine and all it did was piss it off. Could be your problem... Link to comment Share on other sites More sharing options...
mikeinIdaho Posted February 24, 2009 Author Share Posted February 24, 2009 Pissed would be the word! seems like it is doing better already, so I will keep my fingers crossed. a buddy used the Marvel, in both fuel and oil and it made his (same year) Hardbody perk up. Link to comment Share on other sites More sharing options...
nige Posted February 25, 2009 Share Posted February 25, 2009 how are your vacuum lines Link to comment Share on other sites More sharing options...
headpeace Posted February 25, 2009 Share Posted February 25, 2009 if it continues to run poor check the rubber "boot" as the dealer calls it, between the MAF and the intake. Mine did the same thing and I found it was split on the bottom right at the intake, very hard to notice without looking closely with a flashlight Link to comment Share on other sites More sharing options...
edicer2 Posted February 25, 2009 Share Posted February 25, 2009 I have a MAF if u need it Link to comment Share on other sites More sharing options...
burton8it Posted February 25, 2009 Share Posted February 25, 2009 I hope its not the MAF!It is driveable, up through the gears, but if you are over geared-like rolling along 35mph in 4th-it kinda chugs along until the RPMs come up. could this be my O2 sensor? Change plugs/wires or run this tank of fuel with the Marvel in it and start over? The MAF is super easy to clean and worse case there dirt cheap to get a new one and about the fastest fix there is i carry a spare with us when we're wheeling just in case Link to comment Share on other sites More sharing options...
Precise1 Posted February 27, 2009 Share Posted February 27, 2009 also I recently dumped some Marvel Mystery Oil in the fuel tank-so could this be a cause of rough running after coming up to temp? If you are going to dump anything in the tank, use Lucas injector cleaner of something of similar nature. The best way to check for intake/vacuum leaks is to use WD-40 to spray on suspect locations. If the idle surges or changes, you have found a leak. B Link to comment Share on other sites More sharing options...
nismothunder Posted March 6, 2009 Share Posted March 6, 2009 Check the vac line on the rear of the intake on top of the engine.Some thing for fuel presser I think not sure.When I got mine it was unplugged and did what yours did.I put it back on and this past summer it fell off when washing the engine so I was like WTF is wrong with it.Looked back there and it was gone.Went to the local parts store and they wanted a buck for the hose(maybe 4 inchs long) I then left and pulled one off of my old 307 thats sitting in my garage. Link to comment Share on other sites More sharing options...
mikeinIdaho Posted March 6, 2009 Author Share Posted March 6, 2009 I ran the tank through and is got smoother and smoother. Now with a fresh tank of gas it is running GREAT! Even with the Marvel in the last tank I still got 320 Miles of mixed driving. Also the lifter tick I had has gone away! thanks for the input. Link to comment Share on other sites More sharing options...
