unccpathfinder Posted January 21, 2009 Share Posted January 21, 2009 (edited) well i know i've talked in quite a few posts about cheap brake pads and the shims coming loose and hitting the hubs...well as I start to strip parts off of my 87 to fit 95 parts on I noticed it had the "cheap pads" and hten we did the brakes on my housemates 01 Fronty and his "cheap" brakes were worse than mine by a long shot...so here are the pictures so folks know what i've been talking about...the only problem is I forgot to snap a picture of the "nice" pads they werent top line or anything but they had the clips around the sides Caliper removed slipped shims: Fronty slipped shim : where it was hitting the hub...this one is not bad but you can see where it started to turn away the hub (little black line): Fronty shims off pads (notice his drivers sides were eating more at the hubs than the pass side): We got into a discussion about this and inspecting his new pads and i forgot to take pix of his hubs and the new pads but this will give folks an idea of what i've mentioned in other posts and maybe allow folks to keep a heads up on the pads they buy... heres a crappy picture i stole from ebay you can kinda see the clips on this pic: If this should be in the garage section MOD will you please move Edited January 21, 2009 by unccpathfinder Link to comment Share on other sites More sharing options...
Alkorahil Posted January 21, 2009 Share Posted January 21, 2009 Wow. Good you caught it before it got bad. Thanks for the pics, really shows the difference. Having worked in both aftermarket parts for 5 years and now OEM parts, I know there is a difference many, many times in teh quality of parts, I even try to explain it sometimes. Most people are just too far into the walmart/cheap culture to listen anymore. It shoudl strike you odd if your part fits 17 differenct vehicles from 9 different manufacturers.... On the other hand I will also flat up tell someone not to buy something from me sometimes and I will tell them why. Most people do seem to appreciate that honesty though. Link to comment Share on other sites More sharing options...
GrimGreg Posted January 21, 2009 Share Posted January 21, 2009 Usually if the "shim" is a seperate flat piece in the box, I leave it in the box. Link to comment Share on other sites More sharing options...
unccpathfinder Posted January 21, 2009 Author Share Posted January 21, 2009 these are glued/riveted on...the ones that I like to use have 4 tabs bent over and do not let the shim slide off of the pad backing I think if you dont use the shims you can load up the pads unevenly and cause other problems but i never really tried it Link to comment Share on other sites More sharing options...
GrimGreg Posted January 21, 2009 Share Posted January 21, 2009 these are glued/riveted on...the ones that I like to use have 4 tabs bent over and do not let the shim slide off of the pad backing I think if you dont use the shims you can load up the pads unevenly and cause other problems but i never really tried it Well, when my ASE certified father-in-law says, "those are crap just leave those off," I listen to him. Link to comment Share on other sites More sharing options...
Simon Posted January 21, 2009 Share Posted January 21, 2009 The shims are for nothing but noise reduction. IT's fine to leave them off. Link to comment Share on other sites More sharing options...
yozsi Posted January 21, 2009 Share Posted January 21, 2009 Actually the shim is there for prevention of wear on the caliper. If they are glued/riveted to the pad then leave them, if they are separate, leave them off and use some good copper brake lube/anti seize in place of the shim. Link to comment Share on other sites More sharing options...
91PathSE Posted January 22, 2009 Share Posted January 22, 2009 I'm ASE certified....all the shim does is space the caliper out and noise reduction....does nothing important. Link to comment Share on other sites More sharing options...
nunya Posted January 22, 2009 Share Posted January 22, 2009 Parts stores I deal with at work tell us to rip them off and send them to the g-man. Should use lube either way though... Link to comment Share on other sites More sharing options...
unccpathfinder Posted January 22, 2009 Author Share Posted January 22, 2009 just out of curiosity...has anyone run their pads to the bone...the bakc plate hitting the rotors without shims to see if the piston comes out of the caliper...i donno...i think there's more than just a "noise barrier" but thats just me being the skeptical engineer Link to comment Share on other sites More sharing options...
GrimGreg Posted January 22, 2009 Share Posted January 22, 2009 just out of curiosity...has anyone run their pads to the bone...the bakc plate hitting the rotors without shims to see if the piston comes out of the caliper...i donno...i think there's more than just a "noise barrier" but thats just me being the skeptical engineer You mean like this: What a friend of mine brought me, Chrysler New Yorker, the piston was still in the caliper. Link to comment Share on other sites More sharing options...
Simon Posted January 22, 2009 Share Posted January 22, 2009 just out of curiosity...has anyone run their pads to the bone...the bakc plate hitting the rotors without shims to see if the piston comes out of the caliper...i donno...i think there's more than just a "noise barrier" but thats just me being the skeptical engineer Yes, and the piston was still in the caliper. Link to comment Share on other sites More sharing options...
Precise1 Posted January 22, 2009 Share Posted January 22, 2009 What a friend of mine brought me, Chrysler New Yorker, the piston was still in the caliper. GebuS!! Your buddy is damn lucky that rotor didn't grenade on him!! It's worn more than 1/2 way through!! Err, didn't the noise irritate him, if nothing else? B Link to comment Share on other sites More sharing options...
GrimGreg Posted January 22, 2009 Share Posted January 22, 2009 GebuS!! Your buddy is damn lucky that rotor didn't grenade on him!! It's worn more than 1/2 way through!! Err, didn't the noise irritate him, if nothing else? B Suprisingly it made no noise, but there was a lot of debris coming through the wheel. The rotor was about 3/16" thick, and the "pads" were worn halfway through the backing plate, both were 1/8" thick at the thickest. I think what saved him from gernading it was the fact it wasn't a vented rotor, since it was solid it had a continuous wear surface. Link to comment Share on other sites More sharing options...
