how much trimming
BoneZ
I was going to do a 3+3 and 33" tires but once i really got into looking at the suspension and steering assembly, I have changed my mind on that, I will install a 3"bl and try to run 32" tires for now want to know how much trimming will be needed, Then hopefully I will be doing a SAS next winter. I will not have time and money to do it this winter after buying rig fixing broke parts and installing locker, body lift, a few steering upgrades, so it will have to wait tell next winter. Any info on how much trimming would be nice pics of rigs with 3"bl and 32's would be even better.
That all depends on the width of the tire, and the offset of your rims. The more they stick out the more you'll have to trim. If you stay relatively close to stock offset, you shouldn't have to trim much at all.
FWIW, I ran 32's on only a 3" SL for a couple of years with no issues at all.
i ran bfg 32"X11.5" At's with a 3" body lift i just had to remove the inner feder walls no rubbing what so ever
Thanks for the quick reply guy's. guess this is what I will do. On another note, what axles are about the right size for a SAS in these pathfinders besides a waggy axle just want to know what I should be watching for a good deal on. Or can someone post a link to a post with this info on it.
Edited by BoneZ
EB axles are the only other D44 worth considering unless you go full width.. any dana axle under a 44 is crap
  • 3 weeks later...
I've got 17" wheels with 255x75 BFG M/T's on them (about 32's) and I don't have any probs with mine and it's stock.
85 is a 32" tire, 76 is a 31" tire, 71 is a 30" tire
I use this thing. I confuse myself...Sorry about that lol
http://www.dakota-truck.net/TIRECALC/tirecalc.html
LOL! No worries, I wouldn't have known except that in getting these wheels custom machined and ready and looking for sizes to fit them that would look good and fit on my truck I've been over this like 1000+ times in the past 2 months!
They're wheels off a titan I had to have them machined then I painted them with automotive myself then had to make my own custom centers due to the center bore being drilled all the way through and out the front the oem centers no longer worked!
Thanks guys!!
I painted them with a product that has a matte finish then got some stickers off ebay so they'd have that nismo look.
On the metric tire size thing make sure to consider the rim size, On metric tires say you have a 305-70 r15 and a 305-70 r17. the 305-70-r15 will be about a 33" tire, while the 305-70 r17 will be about a 34" tire. Just want to put this out there to try to clarify the confusion.
