yozsi Posted July 11, 2008 Share Posted July 11, 2008 Welp, finally got started on this project. The plan is 3 link suspension, motivation from nissannut's 3 link build. 2 inch .250 wall dom for lower links with ballistic joints, 1.75 inch .25 wall dom for upper link with ballistic joint, 1.75 inch panhard bar with poly bushings both ends, 1.75 inch .25 wall steering, running early bronco front d44 with ox locker, 5.5 inch EB coils front and rear, rear arb or lockrite(depends if i can get my hands on a open carrier or not). Heres how it was before... parts... Link to comment Share on other sites More sharing options...
yozsi Posted July 11, 2008 Author Share Posted July 11, 2008 have to prepare my 40 year old axle for mock up.... ahhh so pretty. time to strip out all that IFS crapola.. how the hell does this happen? OMG no more suspension! good riddance! ok, i also have cut out most of the driver side old ifs brackets... more pics and stuff to come. Link to comment Share on other sites More sharing options...
unccpathfinder Posted July 11, 2008 Share Posted July 11, 2008 looking good...all these SAS's going on and I'm starting to think more and more about it...esp with that dana 44 sitting in my garage with an airlocker...I just hadn't taken the time to figure out gearing and what not...I look forward to seeing the completion of this Link to comment Share on other sites More sharing options...
MY1PATH Posted July 11, 2008 Share Posted July 11, 2008 thats allot of dirt under your skid! wow! Link to comment Share on other sites More sharing options...
yozsi Posted July 11, 2008 Author Share Posted July 11, 2008 (edited) Here is the drivers side frame rail all cleaned up from ifs brackets.... lotta work just to get to this point. coil bucket welded up pile-o-ifs brackets i started on the passengers side but its tough, i gave up for the night. Edited July 11, 2008 by yozsi Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted July 12, 2008 Share Posted July 12, 2008 you're off to a good start Shouldn't be long before you get the front and rear situated! Link to comment Share on other sites More sharing options...
Kittamaru Posted July 12, 2008 Share Posted July 12, 2008 Stupid question - what's the difference between an SAS and a 3 link SAS? Link to comment Share on other sites More sharing options...
yozsi Posted July 12, 2008 Author Share Posted July 12, 2008 Stupid question - what's the difference between an SAS and a 3 link SAS? Nothing they are the same... i just decided to do a 3 link + panhard bar suspension in the front as opposed to leaf springs or triangulated 4 link. Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted July 13, 2008 Share Posted July 13, 2008 SAS - solid axle swap. 3 link, 4 link, and leaf springs are type of suspension systems used for solid axle equipped vehicles. Link to comment Share on other sites More sharing options...
MY1PATH Posted July 14, 2008 Share Posted July 14, 2008 Has anyone ever tried to duplicat the 5-link rear suspension used in wd21 pathys for there SAS? Link to comment Share on other sites More sharing options...
eglaisi_91pathy Posted July 14, 2008 Share Posted July 14, 2008 I don't think there is room for 5 links. Link to comment Share on other sites More sharing options...
MY1PATH Posted July 14, 2008 Share Posted July 14, 2008 I don't think there is room for 5 links. what if you reversed it so that axle is leading the links instead of following them? or would that cause problems? Link to comment Share on other sites More sharing options...
yozsi Posted July 14, 2008 Author Share Posted July 14, 2008 what if you reversed it so that axle is leading the links instead of following them? or would that cause problems? uhhh, you are kidding right? are you thinking that the links go in front of the axle forward? Link to comment Share on other sites More sharing options...
eglaisi_91pathy Posted July 15, 2008 Share Posted July 15, 2008 Yeah, it's already mirrored from the back setup. I think there is barely enough room for 3 links, but that's just speculation from looking at pictures. Link to comment Share on other sites More sharing options...
MY1PATH Posted July 15, 2008 Share Posted July 15, 2008 uhhh, you are kidding right? are you thinking that the links go in front of the axle forward? NVM I'm just a curious one, I'm not doing a SAS Link to comment Share on other sites More sharing options...
MikeV Posted July 16, 2008 Share Posted July 16, 2008 Between you and NissanNut I'm going to get suckered into ditching my IFS soon; Wife will kill me but... where did you get your parts from? (or is it documented on Nissannuts site?) and about how much $ for parts. Have all the tools etc. just wondering about cost (minus gearing and front axle) so I can plan when I can afford to. Link to comment Share on other sites More sharing options...
NissanNut Posted July 16, 2008 Share Posted July 16, 2008 Has anyone ever tried to duplicat the 5-link rear suspension used in wd21 pathys for there SAS? There is plenty of room for another link on the right side. I have pix of an xterra setup that way. I only used the left side for upper link because my setup started as a radius arm and I switched designs half way through. There is definitely room but it will get busy on the right side axle mounts. I also wanted my upper link as high as possible. Very nice build so far. I hope the high pinion does not limit space for the panhard and upper axle mount. You may have to put a bend in the panhard. I started another 3 link on my buddys d22. Only did the cut and turn so far. Link to comment Share on other sites More sharing options...
NissanNut Posted July 16, 2008 Share Posted July 16, 2008 Between you and NissanNut I'm going to get suckered into ditching my IFS soon;Wife will kill me but... where did you get your parts from? (or is it documented on Nissannuts site?) and about how much $ for parts. Have all the tools etc. just wondering about cost (minus gearing and front axle) so I can plan when I can afford to. I have been updating the spreadsheet allot lately. Apparently some part numbers changed at ballistic. http://nissannut.com/projects/SAS_3link There is a price list on XLS. so glad some one is taking advantage of this setup. I am loving it. I just added a sway bar and it drives AWESOME! Link to comment Share on other sites More sharing options...
yozsi Posted July 16, 2008 Author Share Posted July 16, 2008 Very nice build so far. I hope the high pinion does not limit space for the panhard and upper axle mount. You may have to put a bend in the panhard. its a low-pinion axle... the pics are just in a bad angle. Link to comment Share on other sites More sharing options...
NissanNut Posted July 16, 2008 Share Posted July 16, 2008 OK cool. I like that axle plenty of room to mount brackets. I just added 1" spacers up front (1.5 in back) I have a tighter turning radius with no rubbiung now. You may want to cut and turn before you weld all the brackets on. Link to comment Share on other sites More sharing options...
eglaisi_91pathy Posted July 17, 2008 Share Posted July 17, 2008 I just added a sway bar and it drives AWESOME! Did you set it up with quick connects so you can take it off when you go wheelin? That's what I plan to do sometime. Back on track: how come more guys don't move the steering box forward? Link to comment Share on other sites More sharing options...
yozsi Posted July 17, 2008 Author Share Posted July 17, 2008 OK cool. I like that axle plenty of room to mount brackets. I just added 1" spacers up front (1.5 in back) I have a tighter turning radius with no rubbiung now. You may want to cut and turn before you weld all the brackets on. I plan on a cut and turn, right now i have the axle under the truck for pinion angle mock up. im going to weld in the coil buckets so i can figure out ride height. i'm thinking of pushing the axle forward some but i dunno. Link to comment Share on other sites More sharing options...
eglaisi_91pathy Posted July 17, 2008 Share Posted July 17, 2008 Do it! Move it ahead. All you have to do is move the steering box ahead a few inches, trimming of the rad support/bumper support is necessary for this though. You'd make your approach angle alot sexier... something like this: Link to comment Share on other sites More sharing options...
Mookie Posted July 17, 2008 Share Posted July 17, 2008 Back on track: how come more guys don't move the steering box forward? It really depends on how one has setup their front end. Some can position their axle 1-3 inches forward and not move their stock steering box, while some need to move their steering box, or others use a Saginaw box instead. My first round of steering linkage with the axle forward had me using the Saginaw box. After debugging after a few years, I could have modified the drag link and pitman arm and kept the stock box. Lots of variables. Link to comment Share on other sites More sharing options...
yozsi Posted July 17, 2008 Author Share Posted July 17, 2008 Okay, got the drivers side coil bucket all in.. Here is the panhard bar mount, had to cut it and shape it to fit the contour of the frame rail and around the motor mount frame bracket. I made a brace out of 1/4 plate.... over kill but i dont think i will ever have a problem of the shock tower or coil bucket ripping free. I plug welded it in 6 places and stitch welded around the plate to the frame. Coil bucket brackets welded in, i had to shape the right hand bracket because of motor mount frame bracket and contour of frame rail. Bucket installed.. This is how the back side looks like... passenger side starts tommorow. Link to comment Share on other sites More sharing options...
