TheRhyno Posted July 19, 2007 Share Posted July 19, 2007 Ok my check engine light wont go off, but every thing is fine 98 finder....ant ideas? Link to comment Share on other sites More sharing options...
SC88Pathy Posted July 20, 2007 Share Posted July 20, 2007 Have you tried running ECU codes? Link to comment Share on other sites More sharing options...
brerben Posted July 26, 2007 Share Posted July 26, 2007 Check your muffler bearings. Also, your hubcaps could have a leak. Link to comment Share on other sites More sharing options...
94extreme Posted July 26, 2007 Share Posted July 26, 2007 lol.. Link to comment Share on other sites More sharing options...
GhostPath Posted July 26, 2007 Share Posted July 26, 2007 Check your muffler bearings. Also, your hubcaps could have a leak. Lest you think you're being clever, some Jaguars actually have a part called a muffler bearing - it's part of the exhaust mountings. And Rolls Royces with those neat self-orienting logos on the wheels actually have a fluid in the assembly that orients the logos. Thank you for playing, try actually helping the guy next time instead of being about as funny as amateur night at a club in West BFE. Link to comment Share on other sites More sharing options...
GhostPath Posted July 26, 2007 Share Posted July 26, 2007 Ok my check engine light wont go off, but every thing is fine 98 finder....ant ideas? Take it to AutoZone and have them read off the codes for free - that will tell you why the light is on. Link to comment Share on other sites More sharing options...
zonianbrat Posted July 26, 2007 Share Posted July 26, 2007 oooh. burn Link to comment Share on other sites More sharing options...
88pathoffroad Posted July 28, 2007 Share Posted July 28, 2007 lol Link to comment Share on other sites More sharing options...
jjeffri Posted July 30, 2007 Share Posted July 30, 2007 If nothing is wrong, or the light came on and the problem fixed itself, then the light will go out after some number of "driving cycles" I think this amounts to like 15 trips or so, but the actual definition of the "driving cycle" would best be proposed by one of the veterans. If you know it's OK and the light is just ticking you off, you can unplug your battery and that'll reset the ECU, of course, the ECU may need to retune some of its internal parameters after it's effectively rebooted. Best bet is to have someone read out the codes and see what the problem is, assuming you haven't done so already. You can actually buy a code-reader for reasonably cheap (say around $100) if you are finding that you need to check your indicator frequently. Good luck. Link to comment Share on other sites More sharing options...
fondo Posted July 30, 2007 Share Posted July 30, 2007 A "check engine" light could mean anything. Its just telling you that some sensor is not registering in the ecu. I would check your blinker fluid level... j/k. sorry. Link to comment Share on other sites More sharing options...
Casey.T Posted July 30, 2007 Share Posted July 30, 2007 AutoZone can check and clear Codes.... R50 doesnt that also have a Gas Cap indicator??? Auto Zone would be your best Bet.... Long term.... Replacement Part # WD21 Sorry I could not resist.... Link to comment Share on other sites More sharing options...
