Slartibartfast Posted June 11, 2013 Share Posted June 11, 2013 IIRC the ratio differed with auto vs manual trans (usually). Check the info plate in the engine bay (passenger's side, back towards the hinge) for your ratio, it'll say HG and then two numbers. Mine says HG46, meaning 4.6ish:1 gearing, as opposed to the 4.3ish:1 on some rigs). If the donor's tag matches yours, you should be good to go. Link to comment Share on other sites More sharing options...
enkrypt3d Posted July 5, 2013 Share Posted July 5, 2013 Does this conversion improve braking performance significantly? I have x-drilled rotors up front and replaced everything in the braking system but it lacks the bite that I want.. Link to comment Share on other sites More sharing options...
Trogdor636 Posted July 5, 2013 Share Posted July 5, 2013 I've driven both, I don't think its a big difference at all. If you were towing I could see it being worth the upgrade for sure. Link to comment Share on other sites More sharing options...
adamzan Posted July 5, 2013 Share Posted July 5, 2013 I've owned both. My first truck I had for 5 years has drums and now I have a 4 wheel disc truck. Honestly I notice no difference. The drum one actually had a better pedal feel. Link to comment Share on other sites More sharing options...
enkrypt3d Posted July 6, 2013 Share Posted July 6, 2013 well that sucks... I guess the only other option would be to get bigger brakes then right... which are expensive! Link to comment Share on other sites More sharing options...
ferrariowner123 Posted July 6, 2013 Share Posted July 6, 2013 So did I under stand this right? I can swap rear disc's on to my r50? -Kyle Link to comment Share on other sites More sharing options...
enkrypt3d Posted July 12, 2013 Share Posted July 12, 2013 what are the big brake options by the way? whos running bigger rotors / calipers? Link to comment Share on other sites More sharing options...
schro Posted July 14, 2013 Share Posted July 14, 2013 I went up the valley to 'Pick a Part' (the JY) in Chilliwack 2 years ago to pull disc axles off a wreck, and as I was getting the last bolt out my wife called me and told me to get back to the city right away because her water had just broken while she was at work. Our baby boy was born that night (2 weeks early). Needless to say I have not had a lot of time to work on the truck for a while, but the rear brakes were in need of service (trouble lights on) so I dug out the axles from storage, bought new pads (rotors were in great shape) and did the swap yesterday. There is an obvious improvement since going from worn drums to new discs, but the improvement exceeded my expectations. Pedal feels firm and responsive and the braking is better that it ever was (I've had the WD21 since 140000K, currently at 290000K and this is the first rear brake job). I would feel comfortable towing with this truck now. Link to comment Share on other sites More sharing options...
Patti13 Posted November 2, 2013 Share Posted November 2, 2013 Sorry to bring this thread back from the dead. I have 4.3 gears and disc brakes in the rear. My hopes are to pull the 4.6 gears from my parts pathy. May be a dumb question, but I just am not sure if the discs that are with the 4.3 diff will match up with the 4.6. I am a newbie and just don't want to run into any issues. Any help would be huge. Link to comment Share on other sites More sharing options...
AndyC Posted November 2, 2013 Share Posted November 2, 2013 Your brakes will be unaffected by a gear swap. Link to comment Share on other sites More sharing options...
