N6VMO Posted March 19, 2007 Share Posted March 19, 2007 My '88 SE V6 has developed a small coolant leak somewhere under the outlet flange. It is very difficult to locate the source. But, it does stop leaking shortly after the engine warms up. Is this a normal issue with Pathfinders? Thanks. N6VMO Link to comment Share on other sites More sharing options...
94extreme Posted March 19, 2007 Share Posted March 19, 2007 nothing normal about a coolant leak. sorry. Link to comment Share on other sites More sharing options...
N6VMO Posted March 19, 2007 Author Share Posted March 19, 2007 My '88 SE V6 has developed a small coolant leak somewhere under the outlet flange. It is very difficult to locate the source. But, it does stop leaking shortly after the engine warms up. Is this a normal issue with Pathfinders? Thanks. N6VMO I know a coolant leak is not normal. Maybe I should have phrased that question better. Is this normal or known failure in a Pathfinder? Link to comment Share on other sites More sharing options...
fondo Posted March 19, 2007 Share Posted March 19, 2007 Check for bad hoses, loose hose clamps, or the water pump weep hole. The weep hole will leak coolant when the waterpump is bad. Thats when you know to change it. Link to comment Share on other sites More sharing options...
Casey.T Posted March 19, 2007 Share Posted March 19, 2007 Upper by-Pass hose as well... Slick's Fav Hose Link to comment Share on other sites More sharing options...
GrimGreg Posted March 19, 2007 Share Posted March 19, 2007 The weep hole will leak coolant when the waterpump is bad. Thats when you know to change it. :contract: If your's is bad, might as well get ready for a timing belt at the same time . Link to comment Share on other sites More sharing options...
unccpathfinder Posted March 19, 2007 Share Posted March 19, 2007 sounds like a w/p to me if hes saying the output flange is where the fan bolts up...b/c thats right where the weep hole is...when mine went bad it only leaked after city driving but on the highway it never leaked i guess it stayed cool enough to not build up pressure to blow by... Link to comment Share on other sites More sharing options...
N6VMO Posted March 21, 2007 Author Share Posted March 21, 2007 Thanks for the tips guys. Yes, if it is the water pump, I'll change the timing belt too. John Link to comment Share on other sites More sharing options...
unccpathfinder Posted March 26, 2007 Share Posted March 26, 2007 i'd do cam seals as well, possibly the tensioner and valve cover gaskets (i found loosening the rocker arms does make the job a lot easier as suggested in the manual) and a couple of other miscellaneous things (i cant think of them right now) Link to comment Share on other sites More sharing options...
