Brake problems
ILoveMyPatty
Okay, '90 SE, discs all around. I have no braking power. I'll push the pedal down 4/5 of the way and it will just start to work, (no resistance on the pedal until the last 1/5). It seems like they only work by locking up. It's not good.
Where should I start looking for what's wrong?
ok...u have some1 pump up the brakes and theres a bleeder valve on each of the 4 wheels and on the abs sensor...i'll look to find the order but i think its abs valve RR LR RF then LF... do it about 7 or 8 times for each 1 and check to make sure theres plenty of fluid after each go round and u should be good...
a lil note...if ure not noticing any leaks and it starts smoking like a SOB...a guy i know just had 1 go bad and instead of leaking out of the base of the MS it leaked into the booster and started blowing it into the intake and started puffing god awful white smoke...only reason i know is cuze he was like i blew a head gasket and i told him to let me check it out and we foudn that he had no water in the oil and no oil in the water and all the plugs looked normal so we pulled the hose off and noticed if he pumped the brakes brake fluid came out of the vaccum tube...
yes
Wait.. are you saying that you open the valve and then pump????
No you pump several times (I do ten), hold the pedal down , open the valve and let the fluid and hopefully trapped air out, then close it before the pedal is allowed up again.. then repeat.
If you pump with the valve open, then you will suck more air into the system!
yes, do exactly that. that's why you really need a helper.
how did this come about? just when it got cold or over time it weakend?
my thoughts exactly as 88.. you probably need a new MC.
It seemed like it happened all of the sudden, which leads me to believe that it's not air in the system, but a problem with something else. Maybe the master cylinder as 88 said above...
It's getting looked at tomorrow, no way I want to work on it in our parking lot in -15F weather.
changing MC is not really that time consuming not is it really that involved. no matter the ease, working in -15f is a B. i don't think i have had to do anything in that kind of cold yet. knock, knock..
btw. you should (may?) hear some gurgling sounds coming from the vac booster if the mc is shot..
Edited by mzxtreme
I haven't heard any sounds coming from the vac booster, whatever/wherever that is...?
the booster is that round thing on the firewall right in front of the driver.. it's also the thing that the MC hooks onto. sometimes you'll have to have the hood up and your ear close by to hear the sound.. other person would have to press the pedal..
does the pedal work better if you pump it a few times? and have you been losing fluid at all?
Edited by mzxtreme
Yes, the brakes work better if I pump it a few times (a few meaning 10-15)... It's definitely not safe. I haven't been able to see if I've been losing fluid at all, I topped it up on Thursday and on Friday my brother drove me to work. I haven't driven since because I don't feel safe driving it like this.
I'm leaning towards the master cylinder being shot. I got out my Chiltons and looked at removal/installation of the MC, and it seems pretty easy, like you said. The thing is, I don't have time to do it with work, nor do I have the time to drive all the way into town to get a new MC... Looks like it will have to go in tomorrow to get looked at/fixed and I'll have to pay for it... or it will wait until the weekend and I'll drive the fathers '02 F350 superduty... hmmmmm...
I really don't want to pay for labor on it, when I could most likely do it myself.
i'd pull the 2 bolts off of the MC and look in the brake booster to see if thats where hte fluid is going...theres a weep hole on the bottom side of the MC against the booster and usually the fluid leaks there when its going bad...so if not like i stated previously its prob filling up the brake booster
Problem has been solved. Somehow I got air in the lines. My mechanic bled them today while I was at work. I would have done it myself if I knew for sure I had enough fluid to do it. But, next time I will.
I need to replace my brake pads, so I'll be doing that repair myself hopefully :D
Thanks for the help everyone.
