Maz Posted August 27, 2006 Share Posted August 27, 2006 I am looking at getting a body lift for my 91 to clear the tires so I can actually go wheelin again. BUt why do most body lifts only list till 1990? Will these work on my 91? THanks Jamie Link to comment Share on other sites More sharing options...
jj big shoe Posted August 28, 2006 Share Posted August 28, 2006 (edited) According to AC the 90 will fit your 91.Here's a link to their page. Edited August 28, 2006 by jj big shoe Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 28, 2006 Share Posted August 28, 2006 Nissan changed the body mounts in the rear somewhere between 91 and 92, and none of the body lift kit manufacturers bothered to continue making the kits with the correct bolts for the rear mount points that were changed. The body lifts from AC are simply 87-90 kits with the correct rear bolts added to the kit. They found a manufacturer for the bolts, (they're impossible to find anywhere otherwise) which are all you need to make the kit work on the 91-up WD21's. Link to comment Share on other sites More sharing options...
Maz Posted August 28, 2006 Author Share Posted August 28, 2006 which mounts exactly were they? THanks Jamie Link to comment Share on other sites More sharing options...
Iron Locust Posted August 28, 2006 Share Posted August 28, 2006 (edited) Nissan changed the body mounts in the rear somewhere between 91 and 92, and none of the body lift kit manufacturers bothered to continue making the kits with the correct bolts for the rear mount points that were changed. The body lifts from AC are simply 87-90 kits with the correct rear bolts added to the kit. They found a manufacturer for the bolts, (they're impossible to find anywhere otherwise) which are all you need to make the kit work on the 91-up WD21's. For 2" body lift you must use metric bolts (DIN 961): M12x150x1.25 for 3": M12x180x1.25 http://www.fullermetric.com/products/hex/d...ine_thread.html Edited August 28, 2006 by Iron Locust Link to comment Share on other sites More sharing options...
Maz Posted August 29, 2006 Author Share Posted August 29, 2006 so if I buy a kit that is good to pre 90 and get those bolts everything should be ok? Link to comment Share on other sites More sharing options...
RedPath88 Posted August 29, 2006 Share Posted August 29, 2006 Yes, if you can get the bolts Link to comment Share on other sites More sharing options...
GrimGreg Posted August 29, 2006 Share Posted August 29, 2006 McMaster Carr might carry those also. Be sure to get the high grade bolts. Link to comment Share on other sites More sharing options...
Iron Locust Posted August 29, 2006 Share Posted August 29, 2006 McMaster Carr might carry those also. Be sure to get the high grade bolts. 10.9 or 8.8 Link to comment Share on other sites More sharing options...
offroad95pathy Posted September 2, 2006 Share Posted September 2, 2006 When talking about metric fasteners, medium strength is grade 8.8, and high strength is 10.9, preferably, you want high strength 10.9 Link to comment Share on other sites More sharing options...
Iron Locust Posted September 2, 2006 Share Posted September 2, 2006 (edited) When talking about metric fasteners, medium strength is grade 8.8, and high strength is 10.9, preferably, you want high strength 10.9 I used medium strength bolts 8.8. 10.9 is very difficult to find, even in Europe & Russia. Edited September 2, 2006 by Iron Locust Link to comment Share on other sites More sharing options...
Slick Posted September 2, 2006 Share Posted September 2, 2006 my new 91 has a 3" BL.. but the PO didn't know which BL it was. i can take pics if you want? i haven't had the chance to really get under there and investigate yet Link to comment Share on other sites More sharing options...
Maz Posted September 3, 2006 Author Share Posted September 3, 2006 I use 10.9 at work all the time the problem is that it a difficult thread pitch to find probably (p.s. all cat machines use 10.9) Link to comment Share on other sites More sharing options...
DustyDevil Posted September 3, 2006 Share Posted September 3, 2006 when you can't find a bolt locally try Fastenal, or another large fastener manufacturing company...most of them will deal with resale if you can't find what you need. I have had to order other products from them directly.. working on motorcycles mostly, I tend to need a lot of odd sized bolts metric and standard. Also they carry a product called time sert....best spark plug hole thread repair I have ever found! Link to comment Share on other sites More sharing options...
offroad95pathy Posted September 3, 2006 Share Posted September 3, 2006 Nearly all the high strength bolts on Nissans are 1.25 fine pitch, there are a hand full of 1.00 extra fine pitch (ex. the 2 bolts that hold the caliper to the mount bracket), if you come across 1.50 std. pitch, these are usually not high strength bolts, they’re medium strength. As I rework/restore on my Pathy I replace with high strength stainless hardware whenever I can. I get nearly all of it from: http://totallystainless.net I am in the process of a 3”- 4” SL, and they have been able to provide everything I’ve needed so far. Keep in mind, high strength stainless hardware is not cheap. Be careful not to use the stainless hardware sold at most hardware and home supply stores, it’s not the right type for high strength/high torque applications, and it will gall even using antiseize. High strength stainless hardware must be designated “ARP”, or use 17-4 PH grade stainless steel, this grade can also be used for high temp apps like headers and exhaust systems. Link to comment Share on other sites More sharing options...
