nismothunder
Everything posted by nismothunder
  1. Could it be the termosatate sticking,thats one of the things that killed my f150...It was sticking and no heat was coming out of the lines,we would have to pull over and pound on the dash until it unstuck(some reason that always worked) and then have it on full blast until it cooled back down...but then it would close again...
  2. ^ Is in for another night of itching < is tired and sore V should be nunya by this time...
  3. Your banned for not baning the other guy sooner...
  4. *sends a piece of fluff floating towards nunya*hey heads up...
  5. doesnt look that bad,the dumbass should of done the clove box,center condsel,and all the center off the dash insread of just the trim,and then put on a rear momo steering wheel...
  6. or those little hidy holes in the rear,by the amps...they fit liter bottles just fine... or atop the sun visors if they dont get used...
  7. you can order a 20(choice pack) and you get a free humidor for 29,99 plus S@h... but yeah,getting them thrown out would be a b!tch since its your money being thrown down the drain... Why cant you have them at school,are you in some sort of nazi catclic school,I dont see the problem of simply hiding them in your back pack(on this note I assum you have a back pack like mine,where I have a pocket,in a pocket,in a pocket...)or your car,or a friends car,since why would they search,some buddys car.They tryed that with me once(since somebuddy said I had vodka in my mud truck...which no I didnt I had windsor...big diffrence)I told them to check and they couldnt find it(the mudtruck was a mess of tools,empty pop cans,beer cans,and a bunce of muddy clothing)...but yeah,theres all kinds of places to hid stuff in a car,center consel,under the seat,in the little pockets on the door,if you have a spair tire in side,under that...
  8. I think he has 4.37 gears...I dont think going to 31s will affect the rpms that much,since in fact he should be going 85-90 mph if he didnt reset the speedo when he went to bigger tires,I mean 80mph at 2700 rpm is really good,in any truck..., hell in my 150 80 is 2100,but my rear end is ether 3.55 of 3.73...
  9. ok...so I have the 4.6 gear ratio and its at 2900-3000,I would say that bigger tires affect mpg(you should get better mpg if your going steady,wosre if its stop and go) If you have 4.3s you should get better mpg going 70,since the rear end isnt spinning as much...
  10. why would you care if they found out aboot it...really your 18(at least) in colledge... If it was me and my parent got insaly pissed about it I would tell them I had to do it,since all the members of the Aryon nation secontion that you joined do it and since if you didnt they'd think your queer... Naw put it this way...if they find out about it tell them,hey,at least your not a crackhead...
  11. The rod gooses through a hole on a tab on the handle and theres a little rubbery band thing that keeps the rod in the hole...
  12. thank you B...now I'm going to comb my hair into a ducks ass,put on a wife beater and my pin striped suit and go shopping...
  13. Slick...I dont think he's talking about smoking carp or bull head... Its really hard,you ether have to suck on there lips or rear end...and you damn well better have a porpane torqe ready since there not that good at keeping,a coal...
  14. Now let me tell you,the best cigar to smoke is called a phillie blunt water mellon...you guessed it,it tastes just like taking a big hit of nice juicey mellon... And think back,did the cigar have a goldish fole B on it?If so then it was probly a bolivar
  15. And thats a good thing...I prefore no bags,and a lot of metal between me and the other idiots...
  16. well no one else was on the ball...so I stepped up and took it in to my own hands... Yes I know how that sounds...
  17. ^no,couldnt afford postage... <just got done eating a grill chicken samwich Vis not nunya...
  18. ^likes bango music <tthinks Old and in the way was a great album/band Vis about to start yelling...
  19. Bans nunya for being a racist and a sexist...your trucks white,has two doors, and pink around the edge...
  20. YEEEEEEEEEEEEEAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHH no...can not help...but maybe hit up GG,I'm sure he would help you out... Unless your the guy who started the forum I believe your on ya own...Know get collecting pop cans on the side off the road and you'll have anuff in about 212 years...(give or take a decade) Well I donated my ...hoped ya liked it and you put it to good use...
  21. ^true true... <backed into a lite pole(throttle stuck wide open it reverse...damn mpfi fords) Vis hearing banjo music...
  22. Your still keeping the filter thats in the tranny right?If not wont there be fluid pick up problems?
  23. And a happy canadaion zcar day to you as wheel pezzy...
  24. Well if your running any thing thicker then 5w-30 then thats your problem...(and a old starter and or dieing battery) The thiner the oil then the easyer it is to turn the engine over and faster you get the oil up to temp... on a side note my 86 c-vic winter beater would only start if it was plugged in for 3 + hours...it was not a too cold engine problem...it was simply time to replace every wire between the dizzy the block...I replaced the plug wires(no efect) replaced the wires that run to the coil...bingo that was the problem...Simply go out at night,open the hood and have somebuddy crank the engine...you should see lighten in a bottle from the bad wires...that should take care of your problem...(if the engine is turning over fine but not catching...)If the engine is turning over slowly,clean the battery temmanal and see if that helps,if it doesnt change to 5w-30(or evan 5w-20) and see if that helps... You can also help your engine by blocking off some of the radiator to help keep heat in and by putting insulation(the shiny reflextive stuff) on the bottom of the hood to help keep heat in longer after you shut the engine off...
