15
k9sar last won the day on December 18 2023
k9sar had the most liked content!
About k9sar
- Birthday 03/10/1964
05 pathy. lifted 17 just acquired
Skilled/Experienced Mechanic
46+
S
2017
Gender
SE PA
Country
Interests
disruption of all that is good.
15,993 profile views
k9sar's Achievements
NPORA Old-Timer (5/5)
279
I picked up a 2017 S at an auction and have been working on it to become my new daily driver replacing my 05. There are spots in the front bumper that look like they are built to either be filler or able to accept fog lights (with knocking out the circle in the middle). My question is, does anyone know how universal they got with the wiring harnesses in the 2017's? If I pull the bumper cover or dig down near those inserts, will I find a harness hookup for the foglights (as if this were an SV, SL or Platinum) or will I need to do some wiring as well?
yep. dead sensor. RockAuto here I come.
Noticed yesterday that my oil pressure reads maxed all the time (unless the truck is turned off). Even with the key just turned to the on position without the engine running, it flips to maximum. I know this isn't normal but my question is, for an R51, does the pressure read completely low or completely high when the key is first turned on? Can someone take notice and let me know? Deciding whether to chase a bad sensor or bad electrical.
took the easy and relatively cheap path and threw a pair of rear O2 sensors in it. Seemed fine but threw the same 420 code again after a couple of days. Checked with my scanner and it says the one HO2S test failed due to a reading of 0023 with a min of 0033 or something like that. Unfortunately, the damned thing doesn't tell me which sensor it's reading. Thinking I need to do some testing where I disconnect 1 sensor at a time to determine which is for which test then do some reading on what the fruck the measurements are really telling me. No way I'm replacing the cat.
Getting the dreaded cat inefficiency code and got to thinking what is really being measured. I know some people use a spark plug non-fouler but that only would work if the shop doesn't visually inspect the emissions. Has anyone actually modified the O2 sensor itself to get a 'tweaked' reading? I've seen videos on adding a resistor in series and a capacitor in parallel but that would be visible too unless it was hidden well. I was thinking of modifying the tip so not as much exhaust gas gets into the sensor. Disclaimer... t his is just for a test. I have ordered new O2 sensors but thought I'd mess around with the old ones to perhaps see what impact I could make on the readings. enough rambling.... if you've modded your O2 sensor, what did you do to it? Curious.
Free Lift Kit for your R51 - SFCreation
k9sar replied to fleurys's topic in 2005-2012 R51 Pathfinders
March and still going strong. I haven't swapped my fronts from the old design to the new design but will do so when the weather turns good. Not an issue for daily driver and light conditions but at full flex and load, the bolts could strip out of the spacer (old style only). I discussed this with Steve and he redesigned the front spacers to correct that issue before placing the kits for sale so you won't have to worry about my issue. As an engineer, I reviewed his solution and approve of it so even though I have not run the new design for the front, I am very confident that they will work fine. -
My 79 year old mother's Cadillac SRX (part of my inheritance..eventually) suddenly lost brakes. She came out of a store and when she hit the pedal, it went to the floor. Brakes had been working fine up until then. About a year and a half ago, all the hard lines had been replaced due to corrosion and her pads were replaced about 6 months ago. Anyway, she was able to limp it to her house. I stopped over to take a look and found the following: Running or not, the brake pedal goes to the floor when pressed. The brake fluid reservoir is full. There are no observed leaks around the master cylinder or junction block for the rear lines. After pressing the brakes a dozen or so times to the floor, there was no brake fluid leaked onto the driveway or any leakage around the calipers. So immediately I thought... master cylinder failed and ordered a replacement. Removed the hard lines (2) from the master cylinder and capped/plugged them. Swapped the reservoir to the new master cylinder and filled it with fluid. plugged the ports on the MC and held it in a bench vice. Using an old push-rod from a blown dodge engine, I forced the piston in the MC until it was no longer burping air and the piston was unable to be depressed. I felt that was a successful bench-bleed so I installed it in the vehicle, including using a syringe to add fluid to the rigid lines before installing in the MC (barely took any so I'm thinking that no air should have gotten into the system other than maybe a tiny bubble. I was very careful not to introduce air since it was cold and pouring down rain and I didn't feel like crawling under and bleeding the system. Got everything tight and wiped down... got in the vehicle and tested the brakes..... right to the floor DAMNIT! so, now I'm at a loss as to what the problem could be. What could cause a sudden loss of brakes that did not involve a ruptured line or failed MC? My understanding of the vacuum assist is that there is a hard linkage there through the diaphragm so even if the VA failed, brakes would still work. Any thoughts on where to look next? oh yea, and some clown on the Cadillac forums tried to tell me that a loose hub or wheel axle would cause that since the piston on the caliper would have to push much further if it were loose. He obviously doesn't understand disc brakes.
Replaced the battery. The single digit weather in the northeast finally did it in and starting was a no-go. When I pulled the old battery out, I saw the date code on it.... C9. Damned near lasted 10 years!
Can I use the 'Report' function to report admins who seem to be slacking on their duties or are just too damned lazy to cleanout their inboxes?
If spring rolls around and you are still interested in doing skids, I'd be glad to work with you to get measurements, mock-ups etc. -
Sorry... have been away from the computer for a few days. I have Yokohama Geolander A/T F015's on it. Stock size is 265/70R16 Camber bolts on my 05 are adjustable. Interesting to read Steve's comment about maybe 2005 being the only year. A quick crawl through parts lists or online parts sites may confirm that. I'm not sure what you mean by "at full droop" but my shop was able to get my alignment within spec without spacers/shims/etc. I think I'm going to add another 1" to the rear which will give me 1.5" front and 2" rear. That will give me a little more range/support when I fill the back end with gear/groceries/bricks/dogs/bodies/whatever -
The best way to describe it is... gritty. It is more dry than moist but it is denser than cake. My grandmother used to make it in a cast iron skillet and we'd take it warm, smear it with butter and drizzle home-farmed honey over it. (mouth watering right now)
If anyone has any questions about installation, feel free to shoot me an IM. I did multiple installs to check lift height for different combinations of components so I learned a couple of tricks. Also, Steve's redesign of the front spacers (posts installed) solved the only issue that I found with the prototype design and that issue was not significant unless you are really stressing/flexing the front suspension. Be assured that Steve has safety in mind and has created a nice kit for the R51's. -
Saw pictures of it on the product page of sfcreation.com ... and added oil
Started taking measurements and soaked some nuts with PB Blaster in preparation for installing a lift. Then stopped and fell in the pool since we're in yet another heat wave with indexes around 105 degrees F REALLY tired of summer right now.
