6
Everything posted by Slick
:bow: bow down to the pressure washer gods :bow:
you got it!
make that 4 sssh
it dribbles a bit.. but what i do is tip the filter DOWN and have a rag under it.. haven't had any major spillages yet.. as soon as the filter is off i just hold the hoses upright and lean them against the fuse box until i prime the new filter. i figure a little dribble onna rag is soooo much better than the fight down below! and it is out of the way enuff where i can easily access all other items in that area.. including the fuel filter..fuel lines.. fuse box..etc *****I UNBLOT the filter from my lil "custom" bracket there before removing it from hoses.. so i can have it at any angle i want :idea:
i did it when i pulled the motor in feb.. dunno if it was part of my nightmare *coughs* i mean write up.. but i think there is a write up about the install from someone.. if not.. i can surely do one.... it was easy... and the bracket i have mine bolted to is all homemade.. nothin spectacular but VERY functional and easily acessable.. here's another view (i only hadto drill one mount hole as i used an existing hole in the fenderwell)
and people like YOU are the reason this is such a friendly and informative family!
dunno what year your pathy is.. but here's one at kragens for my 92 for $112... http://www.partsamerica.com/ProductDetail....type=31&ptset=A
i have never had leggos but all my um..nuts were the same.. and no washers
you're welcome Z.. if you were close to me i would have been more than happy to help.. we have a garage a mechanic would envy.. and i have "been there done that" job...lol.. $240 is a good price indeed! as far as the OFRK.. once you get the old filter out.. nice easy install.. just think about where yer gunna mount it up top as you don't want it flapping around loose up there here's where i put mine just for some ideas as far as locations go. GOOD LUCK!!!
-bounce- cool peeps, MAJOR knowledge, wicked cool trucks and good times!! all in one place! can't beat them apples
if i can do it so can you! any possibility of you being able to pull the motor out? makes the job soo much easier... as for the stud.. there have been several write ups about tools, and extraction methods.. including my own experiences (i had 4 broken studs).. is your stud still "grabable" or is it snapped off level with the block?
why not do it yourself? and yes.. $1,000 is OUTRAGEOUS! my gawd! those who will touch it will try to charge you a fortune.. if it is 100% not possible for you to do the job then take it to an import mechanic who ahs done this... inexperienced places like midas..etc.. could EASSILY make matters worse if they have never extracted a broken stud or done this install before.. good luck.. where r u located? sssh
I have AF dripping outta my pipe..along with the lovely smell of gas.... blueish white..all the time... obviously worse when cold.. but stand behind it hot and you can easily get a head rush after 5 mins..lol :oops: i am still trying to pinpoint the problem.. but am leaning towards HG as the injectors would yes.. use fuel and stink.. but NOT cause AF to be lost internally and spit out the back... and my oil STINKS of gas... :oops:
if you tow.. you need torque. unless you race or just can't stand the thought of being beat off the lights (which WILL happen in 99.9% of pathys)... then get the other one.. but i say keep the torque n save yer motor a little extra work
:o whoa.. glad you found the problem before it found you in a wreck! :cool2:
look closely.. you can see mine on the diff...
*sniffles* woot? ok :sniff:
my issue right now .. but i also smell fuel in the oil and out the tailpipe :sniff:
it's all good.. i am not offended.. as i will be the first to admit there are some VERY VERY rude Jeepers otu there.. for instance.. i was the coolest chick on the block while i was wheeling my jeep.. as soon as i parked it and got in the pathy.. said person wanted NOTHING what-so-ever to do with me. his problem not mine. Jeeps and pathys (as pezzy said) have their pros and cons.. and i love each for their individual personalities.. that's what makes wheelin fun...
sssh i don't have an "assembly" on mine.. just 2 stupid lights pokin out.... my bad!
i assume you have checked all ignition related connections? checked yer battery? how old are yer plug wires..plugs...dissy cap n rotor?? alternator been tested? checked the t-belt? changed the fuel filter and filled her up with gas? sssh
-bounce- my bro bought me a new set of headlights last x-mas ($65)
you can not be "sure" unless you've CHECKED FIRST.... run along and go check.. take ya 2 minutes
what he said
