Kingman
Everything posted by Kingman
  1. Mine is an SE. Automagic, power windows and locks, AC that doesn't work, cruise control, sunroof, bullguard and tire carrier, and no fog lights, LSD, or roof rack. The SE seats are very comfy...
  2. Remove the interior door trim and check all the linkages to make sure all the pins are properly seated and not coming undone and binding up. Spray some lubricant on all the moving parts of the lock mechanisms and work back and forth. It should become a little looser. Spray everything that has to do with the lock and door latch mechanism since you're in there already. Oh, and don't pull to hard on the lock... You're likely to break something that way. That's the reason my passenger door can no longer be locked or unlocked from that side.
  3. Stuff you paint on that coats and totally prevents rust from spreading or getting worse.
  4. I'm now in trouble with my teacher for laughing out hahahaha Oh well! Well worth it
  5. Spray the alternator with WD40 first, all inside and out to displace any water that might be causing your issues. I did that with mine and it came right back to life, I thought it was dead as well.
  6. ^^ See, learn something new every day Definitely check the rear brakes and cables.
  7. I've never really known rear brakes to cause something to pull, I'd think it's more the front to do that, with a rubbing caliper or something. But it's possible... Someone who knows more will probably chime in soon...
  8. Cable could be stretched completely, loose and is hanging down so no tension, missing e-brake cable, brake shoes are adjusted all the way in, no brake shoes at all... Get underneath and look, and make sure everything is all there and the e-brake cable is fairly stout. You can see where the cable comes through the floor and has a Y towards the rear axle where the cables then extend to each drum. Also check to see if there is a visible difference in the cable with the e-brake pulled. If that's all good, time to take a look at your drums...
  9. The lift you get for 4x4 is the same for 2x4. http://purenissan.com/wd21_3_kit.htm
  10. HEY! Do not deny me my bacon rights! Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon Bacon
  11. 205k...running the exact same as it did at 203k... The miles just keep on tickin by...
  12. I'm pretty sure I just saw some more bacon pop up...
  13. Mythbusters did it! And it worked! Along with Coke for coolant! And mothballs for higher octane fuel!
  14. Fuel economy - My explorer averaged 21mpg with 215k, and the Cherokee averages 19 mpg with 128k. I remember reading a review a while back about a 1993 Pathfinder SE and somewhere it said "but this great package is set back by the poorl fuel economy. We averaged a dismal 14 mpg during our test." But the interior is really roomy giving the total size of the vehicle...even with the front seat all the way back, there's plenty of room back there. The Explorer and Jeep are pretty cramped back there if the front people want any room for themselves. And the test wasn't crap - to the la de da normal people who don't know any better and want something comfortable that can go off road. Of course WE look at that and go yeah whatever, because we are off road people, who take the off road seriously and realize the stiff suspension is better, the ground clearance and better tires are better, etc. The other person is going to want it to be comfortable and easy to take off road, so they look for the softest suspension and find the easiest to use (the push button 4x4 in the Explorer). The test took those rigs through stuff that most SUV owners will NEVER see. I doubt any of those specific trucks they had there ever saw another spec of dirt after the new owner bought them.
  15. All swaybar parts are new besides the sway bar its-self. Shocks are old, you already know that. Going to replace them when I get the money.
  16. Can a shop fab some up and weld them on?
  17. Inform me... But turns on a dime compared to what? Anything can turn on a dime to someone before they drive something that turns better...
  18. I rhino lined some pieces But it keeps saying dynamic images are not allowed in
  19. My passenger rocker panel is mashed in a few inches, and so is the bottom of the door. Like TheCrow said, scar from the battlefield I was quoted $775 to fix the rocker panel, door, and paint it.
  20. X2. Keep that... What kind of improvement does polishing the TB give?
