Cuong Nguyen
Everything posted by Cuong Nguyen
  1. Might be a simple fix. Could be your shifter lever is not adjusted right or loose. Sent from my SAMSUNG-SM-N920A using Tapatalk
  2. Looks great Sent from my SAMSUNG-SM-N920A using Tapatalk
  3. How much downward travel do you have left in the rear suspension at ride height with the lift? Sent from my SAMSUNG-SM-N920A using Tapatalk
  4. How much droop do you have left in the rear suspension? Sent from my SAMSUNG-SM-N920A using Tapatalk
  5. Thr revolution sensor is on the transfer case adapter I think or on the tranny Held in by a 10mm bolt. It's no 19mm bolt for sure. The transmission diagnostics is very similar If not the same as the 94 so you can use the fsm for that. It's possible that you could have burned clutches. Did you see any metal shavings? Sent from my SAMSUNG-SM-N920A using Tapatalk
  6. Yeah you can. Sent from my SAMSUNG-SM-N920A using Tapatalk
  7. Just compare the wiring color and then you will know. That's what I had to do. Sent from my SAMSUNG-SM-N920A using Tapatalk
  8. I think it'd just a simple monetary switch. Just wire the switch to the neutral wires. Sent from my SAMSUNG-SM-N920A using Tapatalk
  9. I can get in touch with him and ask. Shoot me a pm Sent from my SAMSUNG-SM-N920A using Tapatalk
  10. Yup. Sent from my SAMSUNG-SM-N920A using Tapatalk
  11. Should bolt up with no issues. Don't know the gear g from the zs but sounds like you do. Sent from my SAMSUNG-SM-N920A using Tapatalk
  12. Yeah the t case just bolts up to the rear so I don't think it should matter how it's operated. Sent from my SAMSUNG-SM-N920A using Tapatalk
  13. Do you have the 3.5l? If you do they beefed up the internals. So I would not recommend using from a 3.3l. As long as the transmission came from a manual shift and a 3.5l it is the same for all I know right now. I may be wrong so someone might have to correct me if so. Rebuild is not hard once you start taking it apart. Sent from my SAMSUNG-SM-N920A using Tapatalk
  14. It's a common issue thst the nozzles clog up. The other issue is the rear washer pump seizes up. You can poke through the nozzles with a pin or needle to clear it out. Now to test the pump. Have someone press on the switch and see or hear if the pump spins. It's rearward of the washer fluid tank. Sent from my SAMSUNG-SM-N920A using Tapatalk
  15. Nissan4wheelers.com Sent from my SAMSUNG-SM-N920A using Tapatalk
  16. Stsrted my shift kit install. Sent from my SAMSUNG-SM-N920A using Tapatalk
  17. I know a guy with a transmission from an xterra 2wd and in Tennessee. How's the fluid color and level? When was the last time the fluid was changed? Original copper radiator or plastic? Could be electrical like one of the solenoids. Sent from my SAMSUNG-SM-N920A using Tapatalk
  18. It could be a poor faulty ground for the man sensor. It's a common issue. Also, you could have a faulty injector. They can become dead or stuck open. Sent from my SAMSUNG-SM-N920A using Tapatalk
  19. Cool stuff Sent from my SAMSUNG-SM-N920A using Tapatalk
  20. https://www.radioshack.com/products/radioshack-12v-microlamps-2-pack?variant=5717331205 Sent from my SAMSUNG-SM-N920A using Tapatalk
  21. they just pop out with some gently prying but the wires are short to begin with on some of the switches so you might need to remove the dash trim to get to them. This lead to my steering column cover splitting.
  22. It's like any other timing belt job so you will need to take the belt off to remove the pump. Sent from my SAMSUNG-SM-N920A using Tapatalk
  23. Check your transmission harness and make sure it didn't melt against your exhaust. I suggest you download the automatic transmission portion of the fsm and go through the troubleshooting procedure. Sounds like an electrical related issue to me but I am not well versed with the transmission yet. Sent from my SAMSUNG-SM-N920A using Tapatalk
  24. So sad and mad. Just when I thought I saw the light at the end of this tunnel... Good news, I replaced the bushes inside the oil pump. The ****** news: . Sent from my SAMSUNG-SM-N920A using Tapatalk
  25. You could tap into the park or neutral wires of the inhibitor switch harness Sent from my SAMSUNG-SM-N920A using Tapatalk
