Trialsin26
Everything posted by Trialsin26
Rear spring spacers? I have searched high and low.
Trialsin26 replied to Trialsin26's topic in 96-2004 R50 Pathfinders
6.2 is the OD. I really do now want to replace the rear springs as I'm happy with the EMU. I could always try the AIR Lift system. Anyone ever us it? -
I mounted mine behind the grill. A set of 100w KC lights. It worked well for my 2001 Pathfinder because of the Honey Cone (sp) grill. I had to fab up some mounts but besides that no problem, plus no drilling into the bumper, etc.
They are old man EMU springs and they measure about 6.2 inches in the center coil. I wonder if the spacer will still work? -
Can anyone tell me if anyone makes a 1 inch rear coil spring space for the R50. I'm looking for ones that will fit on the top or bottom and not in the spring. If there is not one made for the Pathfinder is there a universal one or one for another vehicle I can use? Thank you. Sorry if this is a repost but I cannot find a good answer.
Have any of you guys had issues with vibration at highway speeds, tire issues, or bearing issues when using the 1.25inch spacers?
It's been awhile since I have been on NPORA. I wanted to get some opinions on tires. I'm currently running 225/75 on stock 16s which is narrower then the stock 255/65 but a little taller. My question is what is the larges tire I can fit on stock 16inch rims, without rubbing if I use 4x4parts 1 1/4 inch spacers in the front only. I was looking at 265/70 or a little smaller 255/70. Thanks for any help and if you have an opinion about the spacers please let me know. I want to add that i have about a 1 to 1.5 inch lift. Thanks
Just my additional 2 cents. The guy that tinted my sunroof has been tinting windows for years. He tinted my windows on my old Honda civic, my mothers car, a couple of friends, and several people from my work. He did not seem worried about tinting the sunroof at 20% so I didn't worry about it. I live in Memphis and gets around 100 degrees here in the summer. My car sits outside in direct sunlight for at least 9 hours a day while I'm at work. The sunroof is made out of the same glass as your side windows (correct me if I'm wrong). Anyway I have not had any problems with the tint or glass, so it would be safe to say it's ok to tint the sun roof if you want. Just to note, my girl friend has an 02 CRV and her sunroof came tinted about 20 to 25% from the factory (or would you call that smoked??)..anyway.
Well a year now and it hasn’t exploded :oops: . The guy that tinted my windows was kind of weary to tint the sun roof b/c he thought it might be tempered glass like your windshield, but we found out it wasn’t so he said it would be fine.
I had my sunroof tinted when I did the windows. 20%
How to get passenger side rear cargo panel off?
Trialsin26 replied to big_johnson's topic in 96-2004 R50 Pathfinders
If it is the factory wiring harness it should plug right in? That is how mine was, when I took my dad's hitch and factory wire harness from his pathy. -
Your fuel tank is on the driver's side, and if it is full the pathy will sag on that side. It is more noticeable with stock suspension.
Watch out for this camber adjustment kit "if it's really bothering you, go here: http://www.ingallseng.com/parts/81260.htm". Someone on this list had something similar at the bolts broke causing a grand in damage. Most alignment place can make a custom adjustment and get it pretty close to stock.
Ball Joint maybe? But if that was the case you would have a lot more trouble and probably wouldn't be driving.
R50 Hidden Winch Mount recovery system
Trialsin26 replied to Runnerman's topic in 96-2004 R50 Pathfinders
Nice! -
I haven't bleed my brakes yet but I think I read that the 2wd's don't have the LSV? Correct me if I'm wrong???
Didn't work for me. I got the FSM on CD .pdf files from ebay for about $10.00, plus I use my Haynes. They work pretty good as a team.
99.5 looks like we have double post here Take a look at this, this is what I have and you should have the same. In Cabin Air Filter
On the R50 i don't think that is a problem the adjustment is on the light it's self and does not depend on how the light is placed back on the truck. It bolts back in the same place with no adjustment.
Can you tell where the filter is? It should be in the middle of the black box. Nothing else should hold it in besides that clip. It might just be a tight fit, I had to work a little on mine before it came lose. Make sure to remove the bottom on first, then slide the top one down to where the bottom one was and pull it out. There shoud be two filters. As far as I know there should not be anything holding it in besides the clip at the bottom.
Just use figure B and C There are two screws hidden behind the piece that slides out side ways. Here is a quick breakdown. You have one screw behind the grill, so you have to remove the grill. You have one (i think, if not you have to remove it anyway to remove the headlight) behind the blinker, and then you have two screws where that piece slides out. Make sure you slide it to the side and do not pull it straight out. That should do it and you should be able to remove the head light. It will suck the first time you do it so go ahead and replace both head lights at the same time. I tried the first time to remove it form inside the engine bay but the battery and air cleaner made it imposable.
I don't know if this helps but check out the picture below. I had to remove the grill and etc to get mine replace. The picture only shows the removal of the headlights not the grill. The grill is only held on by five clips
I'm not really sure what you are having problems with, is it removing the filter or the inner glove box? If it's the filter there shouldn't be a screw holding it in, only a clip. If it is the inner glove box and there is one point the wont come undone you might want to unscrew the molding right above the glove box that says pathfinder, there is a hidden screw there. I don't know if this helps because it could be different from 99.5 to my 2001.
Runner- you can put me down for one but when I can order it depends on the price and shipping cost, but I guess you will have a better idea once you have it made. I would also be interested in the sliders. How do you plan to make them? More like the Rock Sliders where the stick out a bit so you can use them as a step, or more tucked under the truck? I will also be ordering a skid plate from you this summer. I need to purchase a new Optimum battery first.
PF LE - check it while the car is running and warmed up a bit. This should give you the correct reading. It should read between the Warm and Cold but I could be wrong since I have a MT and not really sure how the auto is set up.
You da man Pezzy, I mean wo-man!
