101
Everything posted by mjotrainbrain
Intelligent Cruise Control Swap?
mjotrainbrain replied to mjotrainbrain's topic in 96-2004 R50 Pathfinders
I've been looking at local yards for 6 months and haven't had luck. With the amount of rough use I see in this thing's future I'd rather not have to deal with long periods waiting to find another sensor. Plus I'll be putting a custom winch bumper on it soon which will likely obstruct the sensor's view anyway. But yes, that would be the ideal solution and I've certainly tried. -
I was thinking maybe I could just remove my sensor and cruise control computer and replace it with one from a regular cruise Pathfinder? Maybe I would have to change out the button cluster on the wheel as well, but I'm willing. -
My 2002 QX4 has the ICC system which is nice but a pain in the butt to diagnose and expensive to repair...and of course it's broken. The dealer claims it's the sensor, but I don't know if they're just saying that because it's the most expensive part. I've been wondering if it would be possible to switch a regular cruise control system in, but I can't seem to find any diagrams that would confirm/disprove this idea. Does anybody know if this is possible? Maybe somebody has upgraded to the ICC? I'm sure it's possible, but I'm hoping it could be done without doing anything other than plugging some different parts in. If it is possible, anybody know what parts I would need to get?
Would this work on an R50 with the auto-mode transfer case? I just got home with one from the junkyard and can't seem to find a way to get it on, but maybe I'm just missing something very obvious.
Looking to replace Interior Lights with LED's
mjotrainbrain replied to joebetoblame's topic in 96-2004 R50 Pathfinders
There's a thread (maybe on a different forum) with the #s for replacing all of the interior lights with LED. I know I've seen it, I'll try to find it -
Spacers and OME MD Rear Springs
mjotrainbrain replied to McFalconPunch's topic in 96-2004 R50 Pathfinders
In my opinion it sits a little high, but in the summer I tow a trailer and camp a lot, and it rides level with a heavy load, do I like it. -
Front end clunking over bumps SOLVED
mjotrainbrain replied to ONe21's topic in 96-2004 R50 Pathfinders
Thanks, I figured it out. It didn't solve my clunking though. :-( -
mjotrainbrain replied to RedRider3141's topic in The Garage
New Rain-X wipers and Moog sway bar bushings -
Is the sway bar under tension? If so, how would I go about removing the tension to do this job? -
I haven't yet, since I'm still running stock shocks so the range of motion is the same as it was when it rolled out of the factory. I probably will when I get new shocks, more to be safe rather than sorry. It wasn't very expensive, I just don't feel like bleeding the brakes. -
I have that setup. I'll post a pic when I get a chance. -
Painted a bunch of little things that were annoying me (like the screws in the spoiler). -
Clicking Sound from the Front Left?
That's what I had thought, which is why I replaced it. Maybe I got a defective one and I need to replace it again? I'll check. It feels tight though and looks all right. -
How would I check that? I know where it is, but would there be obvious/noticeable slop if that's the problem? -
No SFD, but it did start mid-way through some wheeling last November. I've washed it a few time since then, but it's worth checking again. Next time I wash it I'll focus closely on the subframe mounts, thanks! -
When I go through to double-check that the sway bar links are tight I'll do that stuff, thanks. -
Yup, it happens while rocking the car. I might make a video tomorrow to show it. -
I really hate these "help me ID this sound" threads but this has been going on for months and is getting worse and I can't figure out what it is! It sounds like something is loose and making a clicking sound as it wiggles around while going over any kind of bump, however I can't find anything loose. I replaced the sway bar end link on that corner and it didn't fix it. I can't feel anything while driving it over the last couple thousand miles since I first noticed it, so I don't think it's a major suspension component. I've got a few ideas, I'm not sure if it's any of them or how to check. 1) CV Joint: Pretty sure this isn't it, as it only happens over bumps, but I don't know how I would go about checking to make sure. 2) Strut Bearing: I have no idea what the symptoms for this are, but I'd heard of people advising to replace these while installing a lift (which I decided not to do) so I wonder if my laziness is catching up to me. 3) Wheel Bearing: It appears that my front wheel bearings are slightly sloppy, so maybe they're making this noise? Don't really know if the sound matches a wheel bearing going bad, but it might be worth looking into. 4) Other Bearing or Bushing: Probably what it is, but there's quite a few to look through...don't even know where to start with this. As I said, I don't think it's anything super important as I haven't noticed any negative side effects, but it's definitely something that moves with the suspension. I don't want to pay somebody to look at it so I've been ignoring it, but lately it's been really warm here in Michigan (60F in February is pretty crazy) and with the window down it's really bothering me. Any suggestions you guys have will be appreciated.
Yes.
Excellent news! In that case I won't need to contact BDS, thanks! I too am interested as to how they perform vs. stock in terms of stiffness.
ANY 2WD GUYS RUNNING AIR LOCKERS?
mjotrainbrain replied to Gusthebus's topic in 96-2004 R50 Pathfinders
Lockers of any kind, or even an LSD rebuild, will improve offroad capability immensely. For gears I am 99% sure about this: there should be a plaque inside the engine bay on the firewall that will say (either HG46 or HG43) which will designate if you have 4.636 gears or 4.363 gears. I haven't looked at mine in a while so I can't remember exactly where it is... To determine if you have an LSD or not you can look on the diff cover, and it will have an orange sticker that says "LSD Oil Only" if it has an LSD. -
Snowboarder12345's Build
mjotrainbrain replied to Snowboarder12345's topic in 96-2004 R50 Pathfinders
It's coming along really good though! Since you have so many bodywork repairs to paint, are you going to redo the entire vehicle? -
Ha, silly Canadian laws and your mudflaps! -
I think some guys in my 4x4 club work for BDS or have close connections, so I'll make a post on the club forums to see if anyone can get better info.
