PathyAndTheJets
PathyAndTheJets last won the day on December 19 2016
PathyAndTheJets had the most liked content!
About PathyAndTheJets
  • Birthday 10/20/1995
    1988 Pathfinder XE VG30 Sitting at 264,000 miles
    XE
    MN
4,411 profile views
PathyAndTheJets's Achievements
NPORA Old-Timer (5/5)
76
  1. Dove into re wiring the rats nest that was my radio. Got rid of all the twisted together wires, put a speaker in the passenger door, and got the equalizer working for the first time since I've owned it. Huge improvement, going to make my commute a lot better. Next weekend I'm going to install the other speaker in the drivers door.
  2. I've got Kenda Klever A/Ts on my pathfinder currently, the BFGs on 10 inch wide wheels were a little rough on the highway, so I swapped the stock wheels off of my pickup. They're just 235/75/15s but they seem to handle well and I haven't had any issues with wear or traction. They did really well in the snow on my truck with open diffs, better than the BFG A/Ts on the Path. I would say for the price, they're a solid choice. I know a couple of guys in the local offroad group that run the M/Ts and I haven't heard any complaints about them.
  3. My brother has those on his '87 and on his '01 X, he likes them a lot. They do well in the snow too. Been on my list for a while, Probably going to be my next purchase.
  4. Left is driver's side. Right is passenger side. Always.
  5. You can always screw in some old f series mirrors. Have those on my 720. Never seen them on a D21 or Pathfinder.
  6. You should be able to remove your locking hub and pull off a snap ring to allow the CV to slide out. That's the only thing that retains it, so I don't know how it could get stuck.
  7. Replaced the crank seal for hopefully the last time. Made a seal protector out of an aerosol can cap, worked perfectly. Another new timing belt since the other one got soaked in oil. Hopefully I don't have to get in there again until 330k! Now for some cleaning and organizing. Hopefully will be picking up a bigger tool box next week.
  8. There are two different Lego wheels. The early ones had mag or shank style lug nuts, later ones had hardened inserts that used standard taper lug nuts. All center caps are interchangeable. They're all 15x7 and same offset.
  9. Installed new drivers window regulator. Should've done that a long time ago. No more broken window Crank handles.
  10. EGR is only active at part throttle, basically cruising speeds. Under load it shuts off, shuts off at idle. Not worth the work to remove the tubes. Unhook and plug the vacuum line to the valve if you feel like you'll get any horses out of bypassing it. Pcv keeps your engine clean. Leave it alone. Replace the valve occasionally. Putting breathers on it just makes a mess. Catch can isn't a bad idea though, especially on worn engines with a lot of blow by. If the equipment functions properly, you won't gain anything by removing or modifying it.
  11. I've found it depends on location. When I was working on mine when I got it in Colorado. Most stuff was on hand at the hub store. Here in MN almost every part is a day out. I've just gotten used to getting everything I think I need in advance and returning what a don't use, or replacing it anyway because it's got almost 270k miles on it.
  12. Serviced my manual hubs, cleaned and lubed up brake hardware. Replaced skid plate bolts with flanged head bolts. Bought a window regulator so I stop breaking Crank handles.
  13. It's a code for a vacuum bypass valve. Which opens up at certain conditions to check the integrity of the evap system. Vacuum supply hoses should be inspected for cracks/leaks, repair if found. Check connections, power to the connector should not exist with engine off. It may toggle on/off when ignition is turned on. Remove valve and blow through it. If you can blow through it, replace it. Valve is stuck open. If unable to blow through it, bench test it with a battery. Should click when energized, and you should be able to blow through it. Replace if it doesn't open.
  14. There is no issue from switching back and forth from synthetic to conventional oil. Old seals might leak with synthetic, but thats it. I usually run rotella T5 synthetic blend diesel oil or a high mileage syn blend. Cleans up the sludge pretty well. High zinc oil is good for our flat tappet engines. Valvoline VR1 or Amsoil ZRod.
